Low Rider Build - Poland ( Video )
Hej Everyone!
I have started my build recently .
I think that it is interesting to have CNC machine at home.
I have bought used parts from polish 3d printing community.
Since making of the video i have made some small progress, but what i am into right now is the software .
I am using Arduino Mega , and cnc.js
but the software to generate gcode - its called estlcam .
Has someone used SOLIDWORKS to generate gcode ?
Video of the building process ( short one ) :
If you can leave a like . ( I will soon make a longer version )
Congrats on getting your LowRider assembled! Hope you can get it up and running and start making stuff! I’ve enjoyed mine and I am currently working to upgrade it from v2 to v3!
I’m also using ESTLcam to generate Gcode for CNC work, after having tried Easel. ESTLcam is just way better than Easel.
Hello I have finally started mine machine - but on the same moment i found out the first problem Ive had - Mine Makita Router - is getting hot preetty fast .
8A7874DC-5331-4481-8691-4711670D79FB
3D Printed Holderfor it just melted - and the whole CNC Machining was ruined .
I need new router for mine cnc - about 500W
I am thinking about purhasing something like that :
Can you recommend me something what should I buy ?
I would stick with the recommended routers. The base plates that come with them will not melt.
I cannot find any list of recomended routers , could you be more specific ?
Thanks.
Hello @malyboa, looks like you’re building LR2. The LR3 docs recommend couple of routers in LR 3 Docs > Tool Mounts section, guessing those same routers are great for LR2 as well?
I used PETG for my tool mount and vac hose holders. But used PLA for everything else, I don’t live in a super hot climate.
The dewalt dw611 or the makita series 700.
I can recommend the Katsu router as a Makita alternative;
Electric Hand Trimmer, Router, Laminator for wood, Carpenter Router, Carpenter Tool : Amazon.de: DIY & Tools
Thank You guys for all the anserws , as DeWalt DW611 is not awaible to purhase ( even used ) in my country , I decided to go with that makita :slight_smile:
thank you and , soon ill post some video of how just everything works.
With
the new router it is working really good . thank you for advice.
Lookin good!
