Doing the belts on my 1st build. Tried a search and do not see it. How do I set the tension on my belts?
Thanks in advance
Thanks in advance
Just tighten the zip ties. You want them pretty pretty tight. A combo of pliers did the trick for this task for me.
It helps to run the lowrider to one end, and tighten from the other end. The end you run it to, just tighten the zips all the way, have all the adjustment on the other end.
So next question. I have a Rambo 1.4 controller. What are my options, sd card, lan, laptop. I can do whatever is best. I also just grabbed a 3d printer so if i grab a laptop I would just dedicate it to the two printing devices
Good idea. I use a laptop connected by usb to the Rambo 1.4, I have more control, I am a newbie.
You can connect a laptop, or run a raspberry pi with v1pi, or use a screen and as card. They all work.
Would that work? $220.00
Belt tensioners for LowRider 2
Below are the ones I used… work perfectly
