I spent today rigging up my z axis end stops but I’m having trouble with homing. It seems like only one side at a time will “listen” to its endstop, while the other will go past and just smash into the switch. I’ve seen either side do. Maybe both sides are intermittent and I just think it’s doing one side or the other. Either way, any advice? m119 appears to report the switches correctly. I’ll add pics if I can figure out how to from my phone
I was sure that I built my LR2 with Y1 and Z1 on the X Min side… But I had Z1 on the X Max side and Y1 on the X Min side. It didn’t matter though because I did have the endstops set up next to the correct motors.
I discovered that I apparently carried the wiring setup over to the LR3, as it’s the same way, but again, it doesn’t matter.
