LowRider 2 plasma table
Hello, friends after a long break from the forum I decided to start build its no more excuse we have 25mm LRv2.
I give my MPCNC workhorse to my wife and the last thing that I cut on it was panels for LR. For now, sides are 20mm MDF and carriage is 12mm. When I get it running I will cut it from steel. The table will be welded from square tubing. I’m planning to use different type of wheels, maby parts that hold the wheels I need to modify but this we will see when I assemble machine in 3d. I will try to provide all the files and plans for changes and table build. try to keep it KISS. For simplicity and just to say that everybody can make it I will use stick welder for the welding process. As a electronic I will try to use GRBL with arduino mega or LinuxCNC with 5axis driver board that i bought for my mpcnc.
This is long-term project as I’m very busy these days. That will be interesting 2019 year :smiley: stay tuned.!
[attachment file=82249]
[attachment file=82250]
Sounds like a good project! I am also going to be doing a LR2 Plasma table. Not sure if I am going to convert my current LR2 into a Transformer for this or just build a separate one. I’m most likely going to convert the one I have now into a multi-purpose machine just because of lack of space in my shop/garage.
Welcome to the LR Plasma club! Mine’s been going strong for a bit now, really happy with the progress. I’m actually in the middle of a v1->v2 upgrade myself. Printed the parts that touch motors in high-temp PLA because I had issues with warping on the regular PLA parts on the last build.
If you have any questions on it, I’d be happy to help. Here’s my build: https://www.v1engineering.com/forum/topic/somd-lowrider-plasma-cnc/
Hello Krzysztof,
sorry to highjack your thread, but I just saw in Google Groups you posted about the M Prime One. Very clean! I might start one soon because I need a second printer (or third, actually), lightweight, small, and I like the idea to save one stepper motor. https://plus.google.com/u/0/communities/108084856251985677965/posts/114901722831508359432
I plan to print with a 0.6mm nozzle (you wrote in the group you will go for a 0.8mm/Volcano?). Are you satisfied with it?
  • the frame is 426 x 170mm in the original files. I don’t need the full build volume in X and Z, do you think I can make the frame smaller, say 350 x 150? I don’t see a reason why not.
  • is the width of frame material crucial? Looks like you used 10mm Wood and painted it black. I have 6mm Alu, 10mm POM or wood as well. Will the prints still fit when I use another width size?
  • The sideplates are designed by yourself I guess. Wanna share? :slight_smile:
You can make all your changes without problem but make Sure that your printer that will produce parts is perfect dial in in x,Y,z and your z is square to build platform i will try to find this plates for you.
i want to build this as well. is there no worries about heat damaging the 3d printer parts?
I print my in PLA and print on her with PLA plastic no wories. But seperate and isolate heated bed:). Btw. Ryan have very nice design of 3d printer that you will achive much better print quality.
Some progress
[attachment file=98234]
I’m using katsu with er11 I made adapter that fit nicely on 611 plate and make some more rom also in disign I include diffuser for motor air.
[attachment file=98501]
[attachment file=98510]
Vacuum attachment ready
[attachment file=98542]
That’s a funny looking plasma torch :wink:
I’ll be following along as I’m building a plasma table too. I’m eager to see your progress.
It will be. I just have all parts for router so why don’t make both. I’m trying to decide what thc to use.
Today I print with tpu bristle for dust shoe and gasket for cyclon separator and start figur out how I ona connect evrything
[attachment file=98717]
I was playing little with my puzzles and I’m pretty sure that I can make it that whey main board will be 5axis TB6560 controlled by Arduino nano with GRBL and end-stops handled by another nano with 2x 2 rerail module for each of double axis that i need to square. step signal and direction signal is going true rerail and when right side hit endstop relay cut off steps when left side hit also endstop relay release and signal is going to grbl that axis is home. Maby it will work with one rerail if i just cut off step signal i need to check it.
[attachment file=98933]
Let me know how you go with this…very interested!
I’ve just started printing my parts so will embark on this journey soon :slight_smile:
Ok some progress table time.
[attachment file=105179]
[attachment file=105180]
[attachment file=105181]
[attachment file=105182]
Looks like you’ve completely changed up your original plans :slight_smile:
I will still make plasma but first I need cnc that works. Just so I’m not finding problems where they aren’t.
So its cut but…
I have problem with my router i bought it from ebay its makita knock off. I get 3 collets for it 6,8,10mm and as far 6mm is legite and no play in bit in 8 and 10 milimeter its geting strong vibration. And i need to use 8 or 10 for my cr11 adapter. Sombay is using maby spindle with lowrider? how is with monting it.
[attachment file=105414]
