Make some more test its look like i need to change bearings on the router. i place long shaft inside 6mm collet and see deflection when moved then i also see that temperature is rasing on end of the shaft where you insert collets when using nr 1 speed and just holding it in hand for 2 minutes i can bearly touch it with my hand. I order new bearing we will see if its help to my problem. Top bearing is 627RS and bottom bearing closest to collet is 6003RS router Katsu for those that may have a similary problem.
Another update I buy a new router. After change bearings on katsu it doesn’t help its look like el-cheapo have of center drilled hole for collet. Because i bought new router without palm base i need to find out different way to mount it and them now it’s cutting like a champ. I think router part it’s done its just dust collection that i need to sort out and i will start working on plasma part now.
[attachment file=108449]
[attachment file=108450]
[attachment file=108451]
Nice!
Laser addon.
[attachment file=108520]
[attachment file=108521]
[attachment file=108522]
[attachment file=108523]
Nicely done!
Would you like to share you Katsu mount for the 611 plate?
