Lowrider GRBL ramps 1.4 problem
Hi everyone! I just set up my Lowrider with Ramps 1.4 and GRBL 5X from this repository: GitHub - fra589/grbl-Mega-5X: 5/6 Axis version of Grbl, the open source, embedded, high performanc
I got almost everything is working fine, even the homing/autosquare which is very cool, the only issue I have is that the motors don’t stay engaged all the time, so when I rise the Z axis it falls back down after a second (as the Lowrider name implies…)
I think it might be something related to the firmware, anyone can help me?
$1=255
This command will cause GRBL not to disable the stepper power once engaged.
The $1 parameter gives a seconds count for how long the steppers remain engaged after the last movement command. Setting it to 255 is “infinite”.
Thank you very much!
Hi can i asked how you got both z and y to clone plz ? Im having a absolute nightmare with mine :frowning: is there any chance i could have a copy of your filmware ?
Thankyou
Luke
hi need to
anyone can help please. ?!
