So today between jobs my lowrider stopped moving. It had been cutting well and nothing during the cuts seemed off. Then it suddenly stopped moving.
The screen comes up and the board looks like its moving normally. I can connect to the board from CNC.js and its responds to commands.
If I use the screen to issue commands X and Y act like they are working even though no motors turn. When I try to move Z I here a slight click from the stepper and the machine resets. If I try a home command I get a System Halted Please Reboot Message.
I’ve got an SKR 1.3 with TCM drivers. I’m using sensor less homing and no endstops. Machine was working happily this AM.
What I’ve tried so far:
Check Power Connections to the Board, look good and measuring 12v
Swapped out Power Supply
Disconnected Z Steppers
Disconnected All Steppers
Disconnected Probe
Unplugged Z Drivers (TMC Connection Error on Screen)
Disconnected Raspberry Pi
Run M501 & M502.
Checked Onboard Fuses.
Nothing seems to have an effect.
I’m out of ideas except maybe flashing the firmware. Any ideas?
Check that you are still getting VMOT power. You can check this (carefully! Don’t short it out!) on the stepper motor blocks.
That’s for an A4988 but a DRV8825 or TMC driver will be the same. You want to be sure that you’re getting VMOT over the 2 pins in the top right.
If you are not, then start looking for blown fuses. Pretty sure those are just the 2 Mini-ATO style fuses next to the power connectors. Make sure that nothing has shorted the power lines before replacing any fuses.
I haven’t checked the VMOT power yet but I did check each controller digipot voltage and all were at 1.1V which is correct. I also checked fuses and both have good continuity on a multimeter.
I’ll check the VMOT in the AM when I have a fresh head.
I also reflashed the board thinking that might help.
Yeah even worse is that I thought the firmware wipe had failed but had forgot to do the factory reset after flashing. Would have saved me a full rewire of the board. Oh well lessons learned.
