It’s really a nothing job 1 hole, 1 part, 3 pockets all with the same bit. Run time is about 40 mins it was about 25 in when this happened. It was still working on the first tool path.
And I misspoke previously when I set it went to 0,0 in fact it went to machine 0,0 as work zero had been set before run. It’s like it tried to xy home in the middle of of a print.
As I type this I have a theory … the laptop went to sleep during the job it’s possible rhat when I woke it up I might have clicked a button inadvertently and queued up a macro from cnc.is does anyone know if it’s possible to inject gcode while a job is in progress?
Also, are you printing via the SD card or USB? I’ve had some WEIRD stuff happen over USB. Once I started using the SD Card and LCD exclusively, never had another hiccup.
CNC.js running on a PI connected via USB my guess is that I somehow hit a homing macro though. Once I fix my current power issue I’ll rerun and see how it goes.
