I have added a Eleksmaker 3.5 watt TTL blue laser to my 52x82 cutting area Lowrider2.
Below is a video of the wiring.
https://youtu.be/XumFnI_QPq0
Hi wayne here could you explain the mapping sequence I have the same setup but cannot get ttl working, basically fan on or off does work but not as expected
Cheers wayne
I’m using an M42 command on a PWM capable pin with RAMPS and Marlin.
Thank you got it working with M106 and M107, on a rambo mini cheers
TTL is 5 volts off of an endstop pin. It is all documented on the website.
I’m a newb, trying to wire up the laser module. Can I ask where you got the two stranded wire with the two pin connector that went from the ttl on the laser board to fan 2 on the rambo? Did you make that wire? If so, where did you get the connectors? For clarification, I have the exact same laser as you, but I have the rambo v1.4 board. I’d also be interested in the laser module housing that you printed in your videos if you’ve posted it anywhere. Thank you sir!
I am running a Rambo mini on a Lowrider2. I’m not sure about the mpcnc wiring. The two pin wire came off a car alarm led.
Oh no I’m wiring up a lowrider2 also. Also, I’m asking about the plug on that two pin wire. Did that plug come from a car alarm?
Yes. The led had the two pin white plug on it. Was an older Viper led.
Ok, how about the resistor? It’s a 1k ohm resistor I see, but how many watts?
And for anybody looking in the future, it looks like the white plug we were talking about is a JST connector with 2mm spacing. Correct me if I’m wrong.
