I’m looking at tearing down my Lowrider to build the LR2, couple of questions;
Can I cut all the plates in 18mm Ply? My current 611 plate feels a little flimsy at 12mm and I’m wondering if 18mm is going to cause me any issues.
I’m considering building a table like this from aluminium square section, I figure it’d be straight and reasonably rigid, perhaps lift into the ceiling when not in use. Is there any reason I shouldn’t? Except the fact that it’s going to cost me money.
The big issue with my last build was the flatness of the table, the Z bars rubbing on the side of the table and I think I can see a twist in the X-rails with cuts that are too fast (that probably is the problem right there)
