Hi,
I’ve started printing for LR3 after I cracked my LR2 by slamming it into the workpiece.
I have nuts and bolts being sent and the linear rails on their way.
And I have a Makita trimmer to use as well.
I also have some questions.
I am assuming that I need new cables for the steppers as the ones from the LR2 kit aren’t the correct type ? As well as cables for the endstops ?
Why do the strut plates have keyholes and slots, when the printed part doesn’t allow you to slide them on that way ? The usual engineering trick is a hole and slot to allow for variation.
Can the Y rail holders be rotated 180 degrees without interfering with the side plates ?
Thanks
A
