I recently finished building my mpcnc and it works great. But when trying to adjust my speed, I get the error code - Unkown command: “M221”
If I tap to clear it, it comes back instantly, and hard to back out from. And makes me unable to change speed.
I have the SKR Pro and the tft35 from V1.
I have tried reflashing with the V1 firmware and still get yhe same error.
M221 is for flow rate… So that’s weird. I’m not surprised you’d have that issue with the stock tft firmware, but I thought I killed all of those in the custom v1 version.
Yeah. I read your comment on that previously, so I followed the links and downloaded your version. Even though its what I originally installed. I tried again, and getting same error…
I didnt think about that, but is it safe to change between modes mid print? I guess if it works i could just run it in marlin mode only…but i like the touch screen. Just got my laser in…
Is this a problem just with me? or is this a firmware issue? Wondering if I should try to reflash to old firmware then back to this firmware?
This might help… I modified the file “SpeedControl.c” in the BTT TFT35 source code to NOT send M221 to the printer if there are ZERO hotends. That fixed the error message for me. Here is what I ended up doing to the speedQuery call in SpeedControl.c…
void speedQuery(void) // ask printer for speed and flow of current hotend //modded to ignore M221
if (infoHost.connected && !infoHost.wait && !speedQueryWait)
if(infoSettings.hotend_count > 0)
speedQueryWait = storeCmd("M220\nM221 D%d\n",heatGetCurrentTool());
else
speedQueryWait = storeCmd("M220\n");
Same issue here. M221 error and it basically makes the TFT unusable until the job is done, as it will just keep popping up so you can’t do anything else before it pops up again.
Can you explain how we can fix this then? I have the same issue but not sure how to incorporate this change in the source code… My limited abilities go as far as flashing a new version of firmware…
Is there a firmware with this correction available? The version I have was downloaded in Feb/2021 from V1 and is the most current available as of today.
Thanks for the help!
The guys who created the V1 version of the TFT firmware would need to make that change as I don’t use the V1 TFT firmware. Maybe Jeffeb3 could make that modification in SpeedControl.c in the V1 firmware?
Or perhaps inhibit the TFT from sending M221 in some other way than I have done when the TFT firmware is in CNC mode (no need for flow percentage M221 if there are no hot ends).
