inverted
(Walter Rotter)
1
I just came back from 4 hardware stores.
I’ve got everything except M3.5 screws
Even got M3.5 nuts but M3.5 x 20 is impossible to find.
It seems that it’s quite hard to find those here in SE Europe.
Can I use M4 screws?
Is there enough room to fit them?
Thank you!
Regards,
Walter
martindb
(Martin DB)
2
M4 works great for me. M3.5 are impossible in Argentina also.
forcerouge
(Dui, ni shuo de dui)
3
Yes, no problem with M4
If it doesn’t fit perfectly, just drill the holes a bit wider
inverted
(Walter Rotter)
4
Thank you guys!
You’ve just saved me from a lot of grief trying to get those screws!
