I’m a bit lost with the dual endstop squaring thing. I downloaded the two Marlin zips that mentions Dual Endstop and Ramps from this link: https://github.com/Allted/Marlin
I can’t see what is the difference between them, so I tried both.
When I send M119 it shows that x_min, x2_min, etc are opened. I checked one by one and they change to Triggered when I touch them. So to that point it seems ok to me.
Then I send a M666 and nothing happens. Nothing gets back. So I try homing with G28 X Y but the motors don’t stop when they reach the first endstop, so I have to disconnect the machine.
Is the dual endstop squaring firmware working? What could be wrong with mine? Sorry for my poor english, I hope you understand (:
Hmmm. I haven’t actually tried M666. I know Ryan did at some point.
Does M119 show the x_min and x_max endstops too?
Have you tried just one axis at a time (G28 X)?
I would have guessed that it wasn’t configured for dual endstops, but you’ve got x2_min in M119 so… Not sure…
Did you get the version from Ryan that had the Configuration_adv.h set by him, or did you set the params yourself? The branch dropdown should show you versions like MPCNC_Ramps_T8_16T_LCD_32step_DualEndstop which is configured for ramps/t*/16T/etc.
I tried both, MPCNC_Ramps_T8_16T_LCD_32Step_DualEndstop and MPCNC_T8_16T_Ramps_LCD_32Step_DualEndstop (weird little difference). Both are in the link I posted. I only changed the steps, I’m using 20T pulleys so instead of 200 I use 160.
When I do M119 it only shows x_min, x2_min, y_min, y2_min and z_min. And I tried G28 X too, it keeps pushing with both motors when it hits first endstop. Maybe the Dual Endstop option is not “finished” in those build I downloaded. I thought the squaring thing was already working since I saw the post in the “front” page.
I couldn’t compile (long path name error) so I deactivated the LCD (I have not a LCD on my machine) and the thing worked, it has to do with the U8gLib I think. I changed steps per revolution to suit my 20T pulleys and deactivated an option that shut down my steppers after a few seconds of use, so my Kress 1050 (heavy thing) always ended sinking on the spoilboard in the middle of a program by its own weight.
I’m using Ramps. I checked the endstops manually first, x_min goes with the closest endstop (to me) on X axis and x_max goes with the other. Same for the Y axis.
So… I’m trying right now… the problem was what you said to me T_T
The endstops where ‘related’ to the furthest stepper. I changed the plugs: x_min to x_max and x_max to x_min, same for the Y axis. G28 X Y and it works right.
Now I’m gonna try the M666 offset thing. I’ll post here if I can make it work or not. Thank you again
It’s supposed to save in the EEPROM if you do the M500, or whatever the command is to save EEPROM settings. It will be reset when you flash, but it should stay in place through resets/power cycles.
It’s good advice to put it in the config as soon as you get it though. I always make great adjustments to my printer, and don’t write them down or put them in the config, and then when I change the firmware for some reason, they disappear. #firstworldproblems.
I’ve done a 550mm square, one diagonal is 864mm and the other 857mm. So 7mm off aprox (measuring tape…). But I’ve tried several M666 commands and it seems to do nothing, I’ll try chaging it in the firmware directly.
The machine still do weird things, sometimes I send G28 X and it does the right thing, move to the endstops on X axis, at other times I send G28 X and the Z axis starts going up until I have to disconnect the power… And I expected to use G28 to square it and then use G92 as I’ve always been using to set my zero. But when I use G92 with this firmware things just go crazy.
This life is so hard… I’ll keep trying tomorrow :’(
EDIT: I’ve measured the square too, it couldn’t be 550mm. It is 607mm each side so my steps calculations must be wrong too T_T Maybe I smash the thing and make a ZenXY…
Are you happy with that? I would be, could you get it better, maybe.
If you are not you should let us have a peak at your pen mount, to get it more accurate than that we have to make sure the pen is not adding to the error.
First off, accuracy above the point you are at is pretty nuts.
If you want to try and take it further for some reason, for this sort of thing now that you have a 100mm base line, do a square as large as you can fit in your machine. Then compare, like is teh X line still 0.2mm longer (that would suggest pen mount wobble not machine inaccuracy). Doing a full sized one will now reveal a lot more about the build.
