My build is 24x24 built to the recommended sizes using the calculator in the instructions. It also has functioning dual end stops.
Why is it, if I move the x and y out to say 400,400, then zero it out and then try to home it, they gantry will move only to 100,100 then stop. If I home it again, it will then move to the limit switches. It’s like it thinks the machine is only 300x300.
I looked at the marlin files but I didn’t see anything that was obvious to me.
