I had ordered up the thin touchpad from the v1 store but had issues keeping it flat under the bit without getting my fingers stuck under the 611 plate. Also attaching the metal clip to the bit was a pain in the ass.
I simply took a rare earth magnet, super glued on a long fastener and installed the wire on with a ring terminal. I rotated the router on the Mount so I can access it from the side.
For the touch pad I used 1/4 aluminum so that it had enough weight to sit flat on its own without getting pushed around with the wire. Drilled a hole in the side and soldered in the wire so it’s all flush.
Super easy to connect with the magnet and toss the plate underneath. Figured I would share as someone else might find this useful.
