So, my MPCNC has been working great for around a year now, and I wondered if I could use it to make some custom waterblocks for my PC, so CPU and GPU. I got 2 GPUs directly next to one another and they are getting quite toasty.
I would not want to make anything special, just simple waterblocks made out of aluminium.
Has anyone ever tried that with the MPCNC?
Well, I use Noctua Industrial fans and the GPUs are still heating themselves to death, because the bottom one can’t get a lot of fresh air and the other one (Vega 64) is running hot, even at low room temperatures
I could only find a single waterblock for the Vega 64, and that one would require more airflow because it only cools the core and the other parts are covered by a huge heatsink. And the other one could be easily water cooled as it is a popular nVidia GPU (GTX 970). But where’s the fun in buying all of that? And I don’t think I could get a lot of that right now.
I might look into buying a waterblock for my GPU, but the CPU should be easier to cool with a DIY block, right? I mean, if Linus Tech Tips can do it…
The bottom might not be perfectly flat, but you can always lap it using high grit wet sandpaper and a flat surface. When we had our quartz countertops put in, I kept all the leftover stock. I use one of those pieces as my flat surface. It’s as close to perfectly flat as I can get in my shop. You could also use a thick piece of glass.
