makita rt0700c
Hi, I have bought a makita rt0700c. It comes with 6 / 8 mm collet. What do I need to buy to use 1/4" and 1/8" endmills/bits? Links would be helpfull. Tnx
I bought this - have the same router as you
https://www.ebay.com.au/itm/6-35mm-1-4-to-3-175mm-1-8-Collet-Adapter-CNC-Router-Reducer-End-Mill/222698236596?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
cheers
Gary
Tnx, is that just for 6mm to 1/8?
Elaire Corp sells different sized collets for the Makita, and they grip better than the stock one, more contact.
i ordered this
https://www.aliexpress.com/item/1set-ER11-C6-60L-C6-ER11-60L-100L-extension-rod-extension-bar-Straight-Shank-with-ER11/32871091240.html?spm=a2g0s.9042311.0.0.27424c4d0AN90B
hasnt show up yet, but another option
elaire makes good collets in different dimensions. Much better than adapters.
Ordered an Elaire 1/8" collet for my Makita rt0701c.
Thanks for the tip
