Manually vs auto creating objects in estlcam
Finally got my machine built and ran the crown like 100 times last night. I have one more image that I would like to run with a pencil before I’m comfortable enough to put a spindle on. The problem is that there are a shit ton of lines to manually select for the object. I tried to have estlcam automatically select them, but it ships parts of the image. Am I doing something wrong? I can upload the dxf that I generated if needed.
You could add those paths in manually, but i suspect that they are just not being displayed. Look at the preview to see if they are there, or zoom into them.
I’ve never tried auto though. Just guessing.
You might also try kust drawing a word or two. You’ll probably find some mistakes and save a ton of time.
