I am starting to gather steel to build my 6 x 9 foot table. I would like to go with an all steel or aluminum set up. Are there any ideas, suggestions, cautions, files or examples I can follow or refer to.
I have the Nema 23 steppers and will be using the heavy duty spindle with speed controller etc. refer to Tom Meyer’s upgraded table as I copied his parts list.
I guess the only caution is weight on the gantry and how much you plan to redesign. You can add stronger steppers but you’re still going to end up with a lot of weight in the middle of two parallel rails. Maybe a four rail system would be better for stiffness but then you’re also left with plastic bearing blocks and lots of weight.
It’s absolutely all possible it’s just a matter of if it will pay off in the end based on what you need it to do.
I agree. One could effect the other in a way that is detrimental. I believe it is breaking it down to one piece at a time. I have Nema 23 high torque, spindle, and metal table. I have already got the 4 poles but plan to use an aluminum plate outside of each set of posts. I wish I knew CAD because I could draw easier
