I printed more then half of the parts (25mm version), and starting the assembly. In the parts list there are M3.5 bolts, which are fine, and M8 bolts and nuts which I do not believe to fit
Most of the holes in my parts are 4mm (3.5mm?) diameter, so that fits specification for M4 (M3.5?) bolts. But, the hexagonal holes/traps for nuts in these parts are 8mm, and that fits the specification for M5 nuts! I can’t find any M4 with 8mm heads… M3.5 uses 5.5mm head, M4 uses 7mm, and M5 uses 8mm…
What bolts / nuts are you actually using?
My first guess is to drill all the holes to M5 size, to utilize 8mm traps/holes but … did I undertood something wrong?
Regarding specified M8 bolts/nuts. They are huge! (8mm diameter of threaded part) I do not believe they will fit in any hole of the printed parts
