my middle assembly is pretty loose and not all of the bearing touch the conduit, do you think it was a bad print as it is the same for X and Y so it would lead me to believe i might have did something wrong. I took my time over a day to put things together so I did follow it down to the letter as much as possible…
The best thing to do is just use it for a little while. Do some drawings and maybe some test Cuts in some wood. Then take it apart and put it back together some people’s printers require a break-in period.
Posted on the FB group at the same time, Christopher Bishop had recommended to tight up the tension bolts and it removed a lot of the play in the middle assembly. putting back into one piece now to test. should be sleeping but caffinee is hellva drug
