Mike the Maker- WI Build
Hello all!
This is Mike from Wisconsin.
I wanted to post my make of the MPCNC and the enclosure I put it in.
I have learned my way through the 3D printing world to finally print out all the Burly parts. I am using a Ramps 1.4 board with dual end-stops. Its a 20"x30"x4" cut area and the enclosure is 37"x47"x24".
Friendly tip I learned- Marlin-config is the way I like to edit the firmware on the MPCNC and the 3D Printers. Easy to use and works great. Links below.
Software From Github
Instructables Marlin-config
Here are some build pics.
Thanks for looking, Your feedback is always welcome!
I like your enclosure. I still need to put doors on mine. I keep putting it off.
Thanks David, I wanted a solution for the noise and dust to be contained.
got done just in time to upgrade to primo :wink: nice work! dig the sign even tho Iā€™m team yellow lol (team red on corded, kept my dads tools dating back many years).
Very nice enclosure!
Thank you.
Did you just glue the door plastic for the window?
Yes. I routed a 1/4" rabbit in so the plexi glass would be flush and ran a bead of silicone to hold it in the door opening. Works great. Definitely cuts down on the noise and dust.
Thanks.
