Using ESTLCAM, from a dxf file produced with Autodesk Fusion 360 I am trying to mill out a set of holes (circles).
The holes have a diameter of 10mm and i’m using a 6mm bit - which i’ve checked the size using calipers. When I measured the holes they consistently came out to 8.2mm.
With ESTLCAM I am telling it to mill out the inside of the hole with allowance set at 0mm. The spacings between the holes is perfect and they are (roughly) round. I am a bit confused as to why the 1.8mm undersize, any ideas?
