Milling Aluminium??
Some members seem to struggle to mill Aluminium an as that’s what I would like to do I thought I’d ask, how difficult is it to get the MPCNC to mill it? Simple light duty cuts nothing too complex, too large the longest cut might be 4-5 inches and slow would be Ok.
Is it a that the machine is pushed right to the limit to achieve it? I don’t want to find that after they effort of doing the build that each cut is a struggle.
Thanks All. Aamcle
It comes down to size of your machine and your experience level. Some can’t do it, some have no issues cutting steel.
Please start with foam, then wood, then plastic, finally aluminum after you figure all that out.
