i’m doing a little test job generator to test feed and plunge speeds.
as a template i have something like this as a plunge speed test (as now it will imply no speed control)
G90 // absolute
G21 // sorry, metric
G1 Z5.000 F500 // safe height, constant
G1 Z-4.000 F{testPlungeSpeed} //i think of -4mm depth as a constant, as i think of it as a quick test.
G0 Z5.000 F500 // safe height again
and this as a feed test
G90
G21
G0 Z5.000 //safe heigth
G0 X-{diameter/2 +startOffset} Y-{diameter*stepover} F2000.0 // start test position at safe heigth
G0 Z-{cutDepth} F500 // cut depth set
G0 X{diameter/2 +cutOffset} F{testFeedSpeed} // the spindle will just go fully in the material
G0 Z5.000 F500 // safe heigth
the problem is, i’m quite ignorant in milling i’m a programmer and i’m doing this test generator also to understand better the concepts.
I agree with Jeff that a straight down plunge is uncommon. I use Fusion 360, and the default settings are always ramping into the wood in some fashion. Often the bit follows a helix path into the wood. The only time I use a straight down plunge is cutting foam where the speed of the plunge does not matter. I’d probably just punt on the plunge test.
As for cutting, to start with what you care about is that for any given wood, bit and toolpath, what depths of cut (DOC), RPMs, and cutting rates work well. Creating a test for these parameters is pretty easy in an any CAD/CAM setup. You can also modify the cutting rate on the fly using a M220 g-code, or some displays allow you to make the the change with a turn of the rotary encoder. And if your router has variable RPM, you can make changes there on the fly as well.
