Hello everyone!
I have finished the mechanical part of my Mpcnc.
(except the belts)
Now I flashed my MiniRambo (China clone…) with the latest firmware for this board that I found here with Arduino IDE 1.9
I attached the motors to the board (only one X and Y, no parallel’ed yet).
The problem is that when I try to move in repetier Host, the movement is very short (not 10mm, if I chose 10mm) and the board seems to restart after the command. The voltage goes down as you see in the Video.
Is my board a problem?
I use a professional 450W - 12V power supply, baudrate etc. was checked to match, I tried different baudrates and changed it in the firmware… nothing helps.
What can you think of?
[attachment file=90591]
[attachment file=90592]
[attachment file=90593]
[attachment file=90594]
[attachment file=90597]
The datasheet of the power supply:
[attachment file=90598]
Rambo:
VID-20190223-WA0011-1.mp4 (1.73 MB)
PM450-32B-1.pdf (436 KB)
