Hello, my name is Patrick and I am putting together my MPCNC in the Chicagoland area.
Before I strap down my MPCNC to a table I wanted to get everything finished so I don’t have to take it a part again and I was wondering if the Mini Rambo will support the dual end stops, or will I have to upgrade to my board?
I can swap it but you also need different wires as well. Most jobs really do not need it, using them also means more CAM work to set them up for every single job. It really depends on what you want to do with your machine.
Tool changes can be done very easily by pausing and you can still use a touchplate to re-zero Z.
