Now that robotics season is over I have gotten back to working with my MPCNC. It was working fine until one day the Y axis quit working. I am sure that it is the channel on the Minirambo board because if I swap the stepper motor wires the other other set of motors work just fine. I was able to go into the arduino configuration files and change the E Motor output and the Y motor output pin assignments and wire up the Y axis motors to the E channel. Now things are working fine again. Any ideas what may have gone wrong? Anything else I should be concerned about?
