My test job is printing on what I believe to be a mirrored Y axis. I followed the advice in this post about flipping the stepper plugs and and changing #define Y_HOME_DIR -1 to #define Y_HOME_DIR 1. This setup causes some of my endstop pins to get redefined.
While normally M119 reports
x_min
x2_min
y_min
y2_min
z_min
Under the modified build M119 reports
x_min
x2_min
y2_max
z_min
I’d appreciate any advice. I think this may be the last bug I need to iron out.
Cheers
Unplug the Y motor cables, flip them 180°, and plug them back in that way.
If for some reason you can’t just flip the Y motor connectors (Say, for example you used JST XH connectors) then change the firmware, in configuration.h change the line:
#define INVERT_Y_DIR true
(If it’s false, change it to true. If it’s true, change it to false.)
You can and should flip the stepper cables if something isn’t going the correct way.
But don’t reverse the endstop direction in the firmware unless you want to learn a lot about the firmware.
You should be able to stand in one spot and the positive Y goes away from you, positive X goes to the right and positive Z goes up. The endstops should be in the close and left sides. You can rotate the whole table after that (or just use your imagination).
Yeah, I’m realizing that I installed my Y axis reversed. My origin is at the rear left of the machine. I just assumed I could make the appropriate changes in the firmware…obviously not. It’s like you said, reversing the endstop direction wreaked havoc. I slept on it and I’m pretty sure I can flip the motors around with a minimum of disassembly.
Though everything was backwards, I’m really impressed with the machine. Looking forward to diving in.
Cheers
