Im sure there is an easy fix for this, probably with my axis. my text is just mirrored when I cut. Anyone know how to fix it?
Problem solved: flipped the x direction
Are you cutting width the text across the x-axis? If so the direction of the x axis motor could be reversed, which can be resolved just by switching the wiring around… And you just posted you solved it… Haha
Thanks Robert!
