I bought the complete kit from the e-shop here, build everything pretty easily and made (what i consider ) a pretty cool piece of geeky technology.
BUT i can’t get my extruder (also bought from here) to work. The stepper won’t turn or just go back and forth from one step to another.
The problem is most likely a wiring problem:
the stepper is not fried as it works with the other axis
the stepper as 4 wires : black and green (that beep together with a continuity test, therefore they must be the same coil) + red and blue.
the jumpers are under every driver.
the extruder is enabled in the Marlin Firmware as the extruder heats up and stabilizes (extremely) well
I hooked up black and green on 1A & 2A on the ramps, same with red and blue going to 1B & 2B.
I expected the motor to at least turn in the wrong direction, have to switch one pair and be good to go. That was in theory.
There is something strange: the stepper of the extruder has a 6 pin connector on it with only 4 wires (see attached picture). Can anyone who bought the extruder from Vicious be king enough to send me a picture of his stepper (with a way to tell me “front” and “back”) and tell me wich wire goes where ? that would at least help to try and understand the problem.
hope someone can help me.
greetings from France
Pierre
ps: more pictures to come once everything will be running. I ended up building a decent rack for all the electronics
If you can’t figure it out telling me wire colors doesn’t help they change all the time. Put the original plug back on and verify it works, then extend 1 wire at a time.
Yep sorry, 1A&B and 2A&B. If you re sure that the plug wiring isn’t faulty then it can (has to ) be my wiring. A pair shoula have the same number and not the same lettre right ? I ll give it a try
The original connector is on the stepper and the wires were indeed extended. I sent the picture in order to be able to compare the position of the wires show were I had them hooked up
