Hello I bought the ramps here but the extruder not. I have everything working correctly but now the extruder is the problem. There is not coming any filament out. I have opened the extruder and tried several things with and without filament and saw that the motor is stuttering/ jammed/ clogging. Even if i pull it completely open so that nothing is hitting anything the motor still stays on the same spot and moves left to right: nothing more.
However, if i say in repetier to pull out 100 filament everything works fine! But the test file that you gave the motor is stuttering/ clogging again. Am I missing something?
So:
- checked everything and everything is working if I put code in to extrude 100 filament (repetier)
- If i put test file from: 3D Printing / Import Extruder | V1 Engineering Inc then the motor doesnt move/ starts stuttering/ clogging.
- If i output 100 on repetier then it outputs ± 3 mm. Maybe this is the problem? But i don’t see anywhere that i need to calibrate it.
Before i brake anything editing software: Hope you can help me
