Was having issues with the LCD not working.
I only hooked up one X Motor and the LCD
The Motor was working, and tested fine, with Repetier-Host.
but was having issues with the LCD click/flash
Tried turning the cables every which way possible, but could not get a picture on the screen
Could get it to light up properly, but no Text.
Tested the LCD on a RAMPS 1.4 and the LCD does work. So that is not the issue.
Decided to re-flash the Rambo with the Firmware as per
https://www.v1engineering.com/marlin-firmware/
Downloaded the Arduino 1.9Beta
Wiped out all references to previous versions of Arduino IDE to start fresh
Loaded https://raw.githubusercontent.com/ultimachine/ArduinoAddons/master/package_ultimachine_index.json
Installed Rambo Board 1.0.1
Installed u8glib 1.19.1
Selected Rambo and COM10
Compiled and Uploaded without issue
LCD is not connected
Motors will no longer move.
Checked Fuses
Repetier-Host will connect
But will not jog motors
Checked Y and Z and other motors, no go.
Note, yes, I did power off the board completely before re-wiring.
Note, motors were working prior to Re-Flash
Note, tried a different Stepper Motor that I know is good, and not working.
I sometimes have issues with Arduino’s holding garbage, so I will load the Blink.ino as a sort of reset.
Light on Rambo does blink as it should.
the board seems to work, but no power to the motors
Possibilities:
- Vref issue?
Also, I do not have a red light on the Rambo indicating incorrect Firmware.
Checking the Cofiguration.h file
Is this correct? #define MOTHERBOARD BOARD_RAMPS_14_EFB
Â
From Repetier
21:03:13.293 : Printer reset detected - initalizing
21:03:13.293 : start
21:03:13.293 : echo:Marlin 1.1.5
21:03:13.293 : echo: Last Updated: 2017-08-28 12:00 | Author: (none, default config)
21:03:13.293 : echo:Compiled: Dec 31 2018
21:03:13.293 : echo: Free Memory: 5508 PlannerBufferBytes: 1232
21:03:13.293 : echo:Hardcoded Default Settings Loaded
21:03:13.293 : echo: G21 ; Units in mm
21:03:13.293 : echo:Filament settings: Disabled
21:03:13.293 : echo: M200 D3.00
21:03:13.293 : echo: M200 D0
21:03:13.309 : echo:Steps per unit:
21:03:13.309 : echo: M92 X80.00 Y80.00 Z4000.00 E500.00
21:03:13.309 : echo:Maximum feedrates (units/s):
21:03:13.309 : echo: M203 X300.00 Y300.00 Z5.00 E25.00
21:03:13.309 : echo:Maximum Acceleration (units/s2):
21:03:13.309 : echo: M201 X3000 Y3000 Z100 E10000
21:03:13.309 : echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
21:03:13.309 : echo: M204 P3000.00 R3000.00 T3000.00
21:03:13.325 : echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
21:03:13.325 : echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00
21:03:13.325 : echo:Home offset:
21:03:13.325 : echo: M206 X0.00 Y0.00 Z0.00
21:03:13.325 : echo:PID settings:
21:03:13.325 : echo: M301 P22.20 I1.08 D114.00
21:03:13.497 : N1 M11034
21:03:13.497 : N2 M11536
21:03:13.497 : N3 M10536
21:03:13.497 : N4 M11435
21:03:13.497 : N5 M111 S698
21:03:13.497 : N6 T060
21:03:13.497 : N7 M2022
21:03:13.497 : N8 M8019
21:03:13.590 : FIRMWARE_NAME:Marlin 1.1.5 (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:3D Printer EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
21:03:13.590 : N9 M220 S100104
21:03:13.590 : N10 M221 S10081
21:03:13.590 : Cap:EEPROM:0
21:03:13.590 : Cap:AUTOREPORT_TEMP:1
21:03:13.590 : Cap:PROGRESS:0
21:03:13.590 : Cap:PRINT_JOB:1
21:03:13.590 : Cap:AUTOLEVEL:0
21:03:13.590 : Cap:Z_PROBE:0
21:03:13.590 : Cap:LEVELING_DATA:0
21:03:13.590 : Cap:SOFTWARE_POWER:0
21:03:13.590 : Cap:TOGGLE_LIGHTS:0
21:03:13.590 : Cap:CASE_LIGHT_BRIGHTNESS:0
21:03:13.590 : Cap:EMERGENCY_PARSER:0
21:03:13.606 : N11 M111 S687
21:03:13.606 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
21:03:13.606 : N12 T09
21:03:13.606 : N13 M155 S1*82
21:03:13.606 : echo:DEBUG:INFO,ERRORS
21:03:13.606 : echo:Active Extruder: 0
