I just finished my first MPCNC build. I put all the parts together, flashed the arduino, plugged the motors into the ramps shield. I downloaded and installed Repetier-Host and was able to successfully connect to the board. I was unable to move any of the motors in any direction. I am not sure where to go from here to resolve the issue.
I did not mess with any of the potentiometers yet as I was hoping at least one of them would be good to go. Good enough to at least move a motor or give a buzzing sound. But nothing.
It just wasnt plugged in there in the photo. When I successfully connect to Repetier and still unable to move the steppers I have both power cable and usb plugged in.
Hello,
I am having the same exact problem and I have the same exact situation,
purchased 3 days ago the rams lcd and cables here not nema 17 and 12V power supply.
But having exactly the same trouble.
Help please
hmmmmm, I’m stumped. Until we get it going make sure you are only using 1 stepper plugged in directly. x y and z to eliminate wiring issues.
But first lets try something. Make sure the power is disconnected. unplug a stepper and short the outer wires of the stepper plug to each other with anything, small piece of wire or paper clip. the stepper should be noticeably harder to turn.
If you were to number the wires in the stepper plug they would be 1234, 1&2 should be a pair and make it hard to turn, same with 3&4.
