I have no idea what defaults are for pronterface or if it has even been update in a very long time. I will more easily be able to help if you stick with the suggested path until we get you going.
Also some details on what you have would help, Board, steppers ect? Pictures also tell me more than you could imagine.
ok i tried repetier no. change. 1 command waiting when i try z move. i have tronxy nema 17 steppers, a full size rambo with discount lcd, a 12v 360w psu. the board and motor wire i purchased from v1
the steppers and psu i got from bangood.
the endstops register the lcd has flashing ? at the axis locations see pics
well i added 12v to the input c still no power to the motors and ? on the lcd repetier still saying 1 command waiting im going to do a reboot of my pc and a cold start on the board just to see what happens. i did a continuity check on the small fuses i got a tone
Pull the fuses out of the board and check for continuity. Everything seems to be correct and the LCD should work if you try to move in the positive direction or select home all.
i did do some testing with these motors on an makerbase sbase untill it stopped flashing for some reason and i did get motor response during those test if that helps
on further in investigation of motors it seems x1 and y1 are responding to the home axis command but not x2 or y2 and if i switch the leads around i can make the other motor turn i have not got a response from z at all.
i believe i need to re-flash the board. i have yet to successfully configure a board. i have ide 1.9 installed and a fresh copy of marlin mpcnc downloaded. is this the next logical move
i just tried to home z and i feel a faint vibration from the motor. it appears there is not enough strength to turn the lead screw. they are 76 oz steppers. i checked for binding and it turns easy enough
i don’t know what is or is not on the board but these values of 95 on motor current look low should i assume 170 to 180 is more to where i want to be on current?
i don’t have a clue i guess it’s time to do the heavy reading.
