Hello,
I’ve been milling with my mpcnc for several months now without any issues. It’s been running the entire time with an extruder and hotend attached to it. But hadn’t gotten around to printing with it since I have two other custom built printers.
For milling I run it either through repetier-server or octoprint.
Now I’m trying to print with it. Yet no matter how I generate the gcode, either with the settings recommended for slic3r or cura or repetier-host (which all things being equal should not make a difference). The machine engages and operates like it’s having a seizure.
The behaviour is such that the machine is jumping around like its getting excessive acceleration pulses. Has anyone seen this behaviour before? Because I haven’t and regularly build 3d printers using ramps and marlin as well as mills usually running linuxcnc or grbl.
If I use gcode generated for milling using either estlcam or vcarve pro the machine moves perfectly.
My ramps is running RC7 currently. It is extremely rigid (its built inside a custom enclosure with the corners milled into the enclosure). I use a dewalt dw660 and its constructed largely with 525 components with the exception of the custom enclosure.
Any ideas would be appreciated.
