I had been thinking of building this for a long time (ever since I saw Bruce Shapiro’s Sisyphus at the Maker Faire in New York), and finally got to finish it this weekend. I’ve used a CoreXY gantry running on VSlots. On its own, the magnet moves smoothly; however, the ball at the top is not smooth at all. It moves in spurts. Not sure what the problem is and how to solve it. Would love to have smooth motion like this:
A good strong magnet in the right pole orientation, the correct size ration between the ball and magnet, and the smallest gap possible. Also try baking soda instead of sand.
I have attached 3 strong disk magnets - what would be the best ratio? I have tried various sizes of balls, including a permanent magnetic ball; the smaller ones were the worst. The large was better, but not perfect.
Mine roll smoother when I use a thinner layer of baking soda as well. Thicker layers increase drag, increasing hysteresis. Moving faster also helps keep the roll going, at the risk of dropping it when moved too fast.
