Claim your Build’s serial number here!
Instructions at the end of this post.
This printer first printed 2021-08-27 -
This is the V1 Engineering MP3DP "Repeat"
Serial - 000001
Took it’s “finished” form on 2021-09-18
Instructions for Serial numbers.
This is the V1 Engineering “Repeat” Serial - 000001 (the placeholders are extremely wishful thinking).
When you think your build is done enough to print. Take a picture, add it here (preferably with a little info), claim your number and display it. If you are unsure what your number is, it should be one higher than the post above yours, it will also be show when you click on the time stamp on the upper right of your post.
You can post and claim as many numbers as you have builds.
No purchase necessary
No other posts in this thread.
