I have been working on my MPCNC for a while now and keep running into the same problem over and over.
Since I haven’t found any topic describing the exact same problem, I have decided to start one.
The problem i’m having is the machine SEEMS to keep ‘hanging’/gets ‘stuck’ on random point, causing the whole print to get off course.
I’ve tried A LOT to come up with a solution on my own. Since i can’t seem to solve it on my own i’m hoping someone could point me in the right direction (any help is greatly appreciated).
My attempts so far:
reassebled middle assembly;
reflashed firmware;
rewired everything;
upgraded to the best quality rods I could find;
added corner supports;
upgraded routers (Chinese to Makita);
tried different belt tensions;
tried different xy speedsettings in Estlcam and feedrates (tried 1200, 1600 and 2400);
tried various bits (currently using an 1/8 (3mm) 2 flute end mill
Possible problems which I believe are definitely not the cause:
Router(s)
Rods
gcode file (one cut turned out perferct)
Since pictures probably are a lot more explanatory, i have added these. Furthermore i have uploaded a video on YouTube (note that this was made before I swapped routers and before i rebuilt the middle assebly). In the video you can hear the motors struggling at around 01:00, around 01:30 things go really wrong.
These things should all be included in your post. It makes it much faster to diagnose problems.
Did you buy everything from here? - No.
a)If you didn’t or changed some things please don’t leave out any details and include what firmware you flashed. - Used firmware from Vicious website.
Are you using end stops? - No.
Mac or PC? - PC.
Include a picture so obvious errors might be spotted. - Added.
Looks like you are using the ESTLCAM firmware, please re-flash back to my marlin one and see if it goes away. I think your settings are incorrect in the estlcam and you are overloading the processor.
Is the recommended z max feedrate of ‘480’ also the recommended value when using a T8 lead screw (instead of a threaded rod), or should a different value be used in Estlcam?
