I have a little Problem with my MPCNC. I use a MPCNC with a Makita Clon Spindel + Arduino & Shield and ESTLCAM. The MPCNC works pretty good, everything works and I had already a lot of fun with it. But since 1 week the MPCNC makes some trouble.
Sometimes completely randomley the MPCNC goes down, very fast, instead of going up. The weird thing is that ESLCAM says that the MPCNC is going up and that anaturally high Z= 80mm, but in reality Z= -30…
You are trying to move teh Z axis too fast, rapids or plunge. I have not used that board or firmware so I can offer no other info. Slow down and you should be okay, no fast than 8/mm/s maybe less depending on that board.
That would be your rapid speed, and as it turns out there is more resistance going up than down. Rapid is up, plunge is down. Most people never set the rapid speeds and try to let the firmware limit it, that is a really bad idea. Set your rapids for XY, and Z separately, that is the basis for all of our Post processors.
