I got a good deal on a different CNC frame from a friend and am selling my barely used MPCNC.
I am selling the entire machine minus the motors, motor wiring and power supply. I currently have it setup for Nema23s on the X and Y axis and a normal Nema17 on Z. I have the cutting area defined as 800 x 550mm in Marlin but I think it can go a little bit bigger. I have beefed up some of the parts and created custom parts but everything is 100% compatible with original MPCNC parts.
What it includes:
Stainless steel rails ( 1", 25.4mm heavy wall from Misumi, I didn't skimp )
All printed parts printed with 4 perimeters, 4 top and bottom layers and 55% infill in Prusa Galaxy Black PLA at a higher temp for good layer bonding. The XY Carriage is printed in white PLA but with the same settings.
A lot of extras ( dust shoes, motor mounts, legs, lots of random parts )
All belts, bearings, nuts, bolts, screw, doo dads, thing-a-ma-bobs needed to put the machine together. I bagged up everything when I tore the machine down.
Dual end-stops and wiring
10mm wide belts ( uses double bearings.. see pictures )
Cable chain / mounts
Mounts for the aviation style plugs ( see pictures )
Dust shoe for DW660
SKR 1.3 32bit controller
5 TMC2208s
Dewalt DW660 Router
Chinese 500W spindle with speed controller, er11 collet and separate power supply
Basically everything you need except the motors, motor wiring and main power supply.
A motor wiring kit from V1 Engineering but I am not sure it will reach all the way to every motor since this is a big setup. I made my own shielded wires to reduce possibility of line noise.
What this does not come with:
Spoil board - you wouldn't want mine anyway, I don't even want it hehe
Motors
Motor wiring ( you do get the V1 Engineering set but it may not be long enough )
Power Supply ( I highly recommend getting a 24V with 15+ amps )
I easily have over $600 and hundreds ( literally hundreds, probably 300+ ) hours of printing in this machine and all the extra pieces.
I am asking $400. If you are in the Southern California area you can come pick it up. I would be willing to ship but buyer pays shipping.
Sorry for the lack of responses. We brought a new daughter into the world and all CNC stuff got put on hold. The machine is still available if anyone is interested.
Hi - I am in Southern California (LA), if this is still avail, I’d love to purchase it and pick it up soon. If avail, reach out to me at: mapa2804@colorado.edu
It is funny because I actually just moved to Fallbrook and brought the MPCNC with me today. I will however be going back and forth between Fallbrook and Vista over the next week almost every day. If you would like to meet up I can bring it back down that way and we can work something out. Let me know when a good time would be to meet up and I will see if I can make it happen on my end.
