So My MPCNC only has 80mm of Z travel and even with that, any rapid direction changes caused visible vibration of the 4 legs. So, since my machine’s table is attached to two walls in a corner of my shop, I figured why not take advantage of the wall for additional support.
The two linked files are simply a wall mountable base and a bolt together “T.” Grab the machine leg with the T and run a piece of conduit between the wall base and the T. Careful not to cause a bind.
For standard American conduit. I printed the T with PETG and the base with PLA. I placed one at the ends of the x and y axes.
