#define CONFIGURATION_ADV_H_VERSION 020000
// @section temperature
//=============================Thermal Settings ============================
#if DISABLED(PIDTEMPBED)
#define BED_CHECK_INTERVAL 5000 // ms between checks in bang-bang control
#if ENABLED(BED_LIMIT_SWITCHING)
#define BED_HYSTERESIS 2 // Only disable heating if T>target+BED_HYSTERESIS and enable heating if T>target-BED_HYSTERESIS
#endif
#endif
- THERMAL_PROTECTION_HYSTERESIS and/or THERMAL_PROTECTION_PERIOD
#if ENABLED(THERMAL_PROTECTION_HOTENDS)
#define THERMAL_PROTECTION_PERIOD 40 // Seconds
#define THERMAL_PROTECTION_HYSTERESIS 4 // Degrees Celsius
//#define ADAPTIVE_FAN_SLOWING // Slow part cooling fan if temperature drops
#if BOTH(ADAPTIVE_FAN_SLOWING, PIDTEMP)
//#define NO_FAN_SLOWING_IN_PID_TUNING // Don’t slow fan speed during M303
#endif
#define WATCH_TEMP_PERIOD 20 // Seconds
#define WATCH_TEMP_INCREASE 2 // Degrees Celsius
#endif
#if ENABLED(THERMAL_PROTECTION_BED)
#define THERMAL_PROTECTION_BED_PERIOD 20 // Seconds
#define THERMAL_PROTECTION_BED_HYSTERESIS 2 // Degrees Celsius
#define WATCH_BED_TEMP_PERIOD 60 // Seconds
#define WATCH_BED_TEMP_INCREASE 2 // Degrees Celsius
#endif
#if ENABLED(THERMAL_PROTECTION_CHAMBER)
#define THERMAL_PROTECTION_CHAMBER_PERIOD 20 // Seconds
#define THERMAL_PROTECTION_CHAMBER_HYSTERESIS 2 // Degrees Celsius
#define WATCH_CHAMBER_TEMP_PERIOD 60 // Seconds
#define WATCH_CHAMBER_TEMP_INCREASE 2 // Degrees Celsius
#endif
#if ENABLED(PIDTEMP)
// Add an experimental additional term to the heater power, proportional to the extrusion speed.
// A well-chosen Kc value should add just enough power to melt the increased material volume.
//#define PID_EXTRUSION_SCALING
#if ENABLED(PID_EXTRUSION_SCALING)
#define DEFAULT_Kc (100) //heating power=Kc*(e_speed)
#define LPQ_MAX_LEN 50
#endif
#endif
#define AUTOTEMP
#if ENABLED(AUTOTEMP)
#define AUTOTEMP_OLDWEIGHT 0.98
#endif
// Show extra position information with ‘M114 D’
//#define M114_DETAIL
// Show Temperature ADC value
// Enable for M105 to include ADC values read from temperature sensors.
//#define SHOW_TEMP_ADC_VALUES
- High Temperature Thermistor Support
// The number of consecutive low temperature errors that can occur
// before a min_temp_error is triggered. (Shouldn’t be more than 10.)
#define MAX_CONSECUTIVE_LOW_TEMPERATURE_ERROR_ALLOWED 8
// This shouldn’t need to be more than 30 seconds (30000)
#define MILLISECONDS_PREHEAT_TIME 20000
// @section extruder
//#define EXTRUDER_RUNOUT_PREVENT
#if ENABLED(EXTRUDER_RUNOUT_PREVENT)
#define EXTRUDER_RUNOUT_MINTEMP 190
#define EXTRUDER_RUNOUT_SECONDS 30
#define EXTRUDER_RUNOUT_SPEED 1500 // (mm/m)
#define EXTRUDER_RUNOUT_EXTRUDE 5 // (mm)
#endif
// Calibration for AD595 / AD8495 sensor to adjust temperature measurements.
// The final temperature is calculated as (measuredTemp * GAIN) + OFFSET.
#define TEMP_SENSOR_AD595_OFFSET 0.0
#define TEMP_SENSOR_AD595_GAIN 1.0
#define TEMP_SENSOR_AD8495_OFFSET 0.0
#define TEMP_SENSOR_AD8495_GAIN 1.0
//#define USE_CONTROLLER_FAN
#if ENABLED(USE_CONTROLLER_FAN)
//#define CONTROLLER_FAN_PIN -1 // Set a custom pin for the controller fan
#define CONTROLLERFAN_SECS 60 // Duration in seconds for the fan to run after all motors are disabled
#define CONTROLLERFAN_SPEED 255 // 255 == full speed
//#define CONTROLLERFAN_SPEED_Z_ONLY 127 // Reduce noise on machines that keep Z enabled
#endif
//#define FAN_KICKSTART_TIME 100
//#define FAN_MIN_PWM 50
//#define FAN_MAX_PWM 128
#if ENABLED(FAST_PWM_FAN)
//#define FAST_PWM_FAN_FREQUENCY 31400
//#define USE_OCR2A_AS_TOP
#endif
#define E0_AUTO_FAN_PIN -1
#define E1_AUTO_FAN_PIN -1
#define E2_AUTO_FAN_PIN -1
#define E3_AUTO_FAN_PIN -1
#define E4_AUTO_FAN_PIN -1
#define E5_AUTO_FAN_PIN -1
#define CHAMBER_AUTO_FAN_PIN -1
#define EXTRUDER_AUTO_FAN_TEMPERATURE 50
#define EXTRUDER_AUTO_FAN_SPEED 250 // 255 == full speed
#define CHAMBER_AUTO_FAN_TEMPERATURE 30
#define CHAMBER_AUTO_FAN_SPEED 255
#define FANMUX0_PIN -1
#define FANMUX1_PIN -1
#define FANMUX2_PIN -1
// @section homing
//#define ENDSTOPS_ALWAYS_ON_DEFAULT
// @section extras
// @section homing
#define X_HOME_BUMP_MM 7
#define Y_HOME_BUMP_MM 7
#define Z_HOME_BUMP_MM 3
#define HOMING_BUMP_DIVISOR { 3, 3, 5 } // Re-Bump Speed Divisor (Divides the Homing Feedrate)
//#define QUICK_HOME // If homing includes X and Y, do a diagonal move initially
//#define HOMING_BACKOFF_MM { 2, 2, 2 } // (mm) Move away from the endstops after homing
// @section motion
#define AXIS_RELATIVE_MODES { false, false, false, false }
//#define MULTI_NOZZLE_DUPLICATION
#define INVERT_X_STEP_PIN false
#define INVERT_Y_STEP_PIN false
#define INVERT_Z_STEP_PIN false
#define INVERT_E_STEP_PIN false
// Default stepper release if idle. Set to 0 to deactivate.
// Steppers will shut down DEFAULT_STEPPER_DEACTIVE_TIME seconds after the last move when DISABLE_INACTIVE_? is true.
// Time can be set by M18 and M84.
#define DEFAULT_STEPPER_DEACTIVE_TIME 1200
#define DISABLE_INACTIVE_X true
#define DISABLE_INACTIVE_Y true
#define DISABLE_INACTIVE_Z true // Set to false if the nozzle will fall down on your printed part when print has finished.
#define DISABLE_INACTIVE_E true
#define DEFAULT_MINIMUMFEEDRATE 0.0 // minimum feedrate
#define DEFAULT_MINTRAVELFEEDRATE 0.0
//#define HOME_AFTER_DEACTIVATE // Require rehoming after steppers are deactivated
// Minimum time that a segment needs to take if the buffer is emptied
#define DEFAULT_MINSEGMENTTIME 20000 // (ms)
// If defined the movements slow down when the look ahead buffer is only half full
#define SLOWDOWN
// Frequency limit
// See nophead’s blog for more info
// Not working O
//#define XY_FREQUENCY_LIMIT 15
// Minimum planner junction speed. Sets the default minimum speed the planner plans for at the end
// of the buffer and all stops. This should not be much greater than zero and should only be changed
// if unwanted behavior is observed on a user’s machine when running at very slow speeds.
#define MINIMUM_PLANNER_SPEED 0.05 // (mm/s)
#define ADAPTIVE_STEP_SMOOTHING
- Custom Microstepping
- Override as-needed for your setup. Up to 3 MS pins are supported.
//#define MICROSTEP1 LOW,LOW,LOW
//#define MICROSTEP2 HIGH,LOW,LOW
//#define MICROSTEP4 LOW,HIGH,LOW
//#define MICROSTEP8 HIGH,HIGH,LOW
//#define MICROSTEP16 LOW,LOW,HIGH
//#define MICROSTEP32 HIGH,LOW,HIGH
// Microstep setting (Only functional when stepper driver microstep pins are connected to MCU.
#define MICROSTEP_MODES { 16, 16, 16, 16, 16, 16 } // [1,2,4,8,16]
//=============================Additional Features===========================
// @section lcd
// Change values more rapidly when the encoder is rotated faster
#define ENCODER_RATE_MULTIPLIER
#if ENABLED(ENCODER_RATE_MULTIPLIER)
#define ENCODER_10X_STEPS_PER_SEC 30 // (steps/s) Encoder rate for 10x speed
#define ENCODER_100X_STEPS_PER_SEC 80 // (steps/s) Encoder rate for 100x speed
#endif
// The timeout (in ms) to return to the status screen from sub-menus
#define LCD_TIMEOUT_TO_STATUS 45000
// Add an ‘M73’ G-code to set the current percentage
//#define LCD_SET_PROGRESS_MANUALLY
#if HAS_PRINT_PROGRESS
//#define PRINT_PROGRESS_SHOW_DECIMALS // Show progress with decimal digits (Graphical LCD only)
//#define SHOW_REMAINING_TIME // Display estimated time to completion (Graphical LCD only)
#endif
#if HAS_CHARACTER_LCD && HAS_PRINT_PROGRESS
//#define LCD_PROGRESS_BAR // Show a progress bar on HD44780 LCDs for SD printing
#if ENABLED(LCD_PROGRESS_BAR)
#define PROGRESS_BAR_BAR_TIME 2000 // (ms) Amount of time to show the bar
#define PROGRESS_BAR_MSG_TIME 3000 // (ms) Amount of time to show the status message
#define PROGRESS_MSG_EXPIRE 0 // (ms) Amount of time to retain the status message (0=forever)
//#define PROGRESS_MSG_ONCE // Show the message for MSG_TIME then clear it
//#define LCD_PROGRESS_BAR_TEST // Add a menu item to test the progress bar
#endif
#endif
#if ENABLED(SDSUPPORT)
#define SD_DETECT_INVERTED
#define SD_FINISHED_STEPPERRELEASE true // Disable steppers when SD Print is finished
#define SD_FINISHED_RELEASECOMMAND “M84 X Y Z E” // You might want to keep the Z enabled so your bed stays in place.
// Reverse SD sort to show “more recent” files first, according to the card’s FAT.
// Since the FAT gets out of order with usage, SDCARD_SORT_ALPHA is recommended.
#define SDCARD_RATHERRECENTFIRST
#define SD_MENU_CONFIRM_START // Confirm the selected SD file before printing
//#define MENU_ADDAUTOSTART // Add a menu option to run auto#.g files
#define EVENT_GCODE_SD_STOP “G28XY” // G-code to run on Stop Print (e.g., “G28XY” or “G27”)
#if HAS_SDCARD_CONNECTION
#define SDCARD_CONNECTION LCD
#endif
#endif // SDSUPPORT
//#define NO_SD_HOST_DRIVE // Disable SD Card access over USB (for security).
- Additional options for Graphical Displays
// Enable to save many cycles by drawing a hollow frame on the Info Screen
#define XYZ_HOLLOW_FRAME
// Enable to save many cycles by drawing a hollow frame on Menu Screens
#define MENU_HOLLOW_FRAME
- Status (Info) Screen customizations
- These options may affect code size and screen render time.
- Custom status screens can forcibly override these settings.
//#define STATUS_COMBINE_HEATERS // Use combined heater images instead of separate ones
//#define STATUS_HOTEND_NUMBERLESS // Use plain hotend icons instead of numbered ones (with 2+ hotends)
#define STATUS_HOTEND_INVERTED // Show solid nozzle bitmaps when heating (Requires STATUS_HOTEND_ANIM)
#define STATUS_HOTEND_ANIM // Use a second bitmap to indicate hotend heating
#define STATUS_BED_ANIM // Use a second bitmap to indicate bed heating
#define STATUS_CHAMBER_ANIM // Use a second bitmap to indicate chamber heating
//#define STATUS_ALT_BED_BITMAP // Use the alternative bed bitmap
//#define STATUS_ALT_FAN_BITMAP // Use the alternative fan bitmap
//#define STATUS_FAN_FRAMES 3 // :[0,1,2,3,4] Number of fan animation frames
//#define STATUS_HEAT_PERCENT // Show heating in a progress bar
//#define BOOT_MARLIN_LOGO_SMALL // Show a smaller Marlin logo on the Boot Screen (saving 399 bytes of flash)
//#define BOOT_MARLIN_LOGO_ANIMATED // Animated Marlin logo. Costs ~3260 (or ~940) bytes of PROGMEM.
enu
#endif // HAS_GRAPHICAL_LCD
// Mappings for boards with a standard RepRapDiscount Display connector
//#define AO_EXP1_PINMAP // AlephObjects CLCD UI EXP1 mapping
//#define AO_EXP2_PINMAP // AlephObjects CLCD UI EXP2 mapping
//#define CR10_TFT_PINMAP // Rudolph Riedel’s CR10 pin mapping
//#define OTHER_PIN_LAYOUT // Define pins manually below
#if ENABLED(OTHER_PIN_LAYOUT)
// The pins for CS and MOD_RESET (PD) must be chosen.
#define CLCD_MOD_RESET 9
#define CLCD_SPI_CS 10
// If using software SPI, specify pins for SCLK, MOSI, MISO
//#define CLCD_USE_SOFT_SPI
#if ENABLED(CLCD_USE_SOFT_SPI)
#define CLCD_SOFT_SPI_MOSI 11
#define CLCD_SOFT_SPI_MISO 12
#define CLCD_SOFT_SPI_SCLK 13
#endif
#endif
// @section safety
#define USE_WATCHDOG
#if ENABLED(USE_WATCHDOG)
//#define WATCHDOG_RESET_MANUAL
#endif
//#define LIN_ADVANCE
#if ENABLED(LIN_ADVANCE)
//#define EXTRA_LIN_ADVANCE_K // Enable for second linear advance constants
#define LIN_ADVANCE_K 0.22 // Unit: mm compression per 1mm/s extruder speed
//#define LA_DEBUG // If enabled, this will generate debug information output over USB.
#endif
// @section extras
// G2/G3 Arc Support
#define ARC_SUPPORT // Disable this feature to save ~3226 bytes
#if ENABLED(ARC_SUPPORT)
#define MM_PER_ARC_SEGMENT .3 // Length of each arc segment
#define MIN_ARC_SEGMENTS 24 // Minimum number of segments in a complete circle
#define N_ARC_CORRECTION 25 // Number of interpolated segments between corrections
//#define ARC_P_CIRCLES // Enable the ‘P’ parameter to specify complete circles
//#define CNC_WORKSPACE_PLANES // Allow G2/G3 to operate in XY, ZX, or YZ planes
#endif
// Support for G5 with XYZE destination and IJPQ offsets. Requires ~2666 bytes.
//#define BEZIER_CURVE_SUPPORT
// Moves (or segments) with fewer steps than this will be joined with the next move
#define MIN_STEPS_PER_SEGMENT 6
// Control heater 0 and heater 1 in parallel.
//#define HEATERS_PARALLEL
//================================= Buffers =================================
// @section hidden
#define BLOCK_BUFFER_SIZE 16 // SD,LCD,Buttons take more memory, block buffer needs to be smaller
#else
#define BLOCK_BUFFER_SIZE 16 // maximize block buffer
#endif
// @section serial
// The ASCII buffer for serial input
#define MAX_CMD_SIZE 96
#define BUFSIZE 4
#define TX_BUFFER_SIZE 0
//#define RX_BUFFER_SIZE 1024
#if RX_BUFFER_SIZE >= 1024
// Enable to have the controller send XON/XOFF control characters to
// the host to signal the RX buffer is becoming full.
//#define SERIAL_XON_XOFF
#endif
// Add M575 G-code to change the baud rate
//#define BAUD_RATE_GCODE
// Enable this option to collect and display the maximum
// RX queue usage after transferring a file to SD.
//#define SERIAL_STATS_MAX_RX_QUEUED
// Enable this option to collect and display the number
// of dropped bytes after a file transfer to SD.
//#define SERIAL_STATS_DROPPED_RX
#endif
//#define EMERGENCY_PARSER
//#define NO_TIMEOUTS 1000 // Milliseconds
//#define ADVANCED_OK
#define SERIAL_OVERRUN_PROTECTION
// @section extras
//#define EXTRA_FAN_SPEED
- Universal tool change settings.
- Applies to all types of extruders except where explicitly noted.
#if EXTRUDERS > 1
// Z raise distance for tool-change, as needed for some extruders
#define TOOLCHANGE_ZRAISE 2 // (mm)
//#define TOOLCHANGE_NO_RETURN // Never return to the previous position on tool-change
// Retract and prime filament on tool-change
#endif
//#define ADVANCED_PAUSE_FEATURE
#if ENABLED(ADVANCED_PAUSE_FEATURE)
#define PAUSE_PARK_RETRACT_FEEDRATE 60 // (mm/s) Initial retract feedrate.
#define PAUSE_PARK_RETRACT_LENGTH 2 // (mm) Initial retract.
// This short retract is done immediately, before parking the nozzle.
#define FILAMENT_CHANGE_UNLOAD_FEEDRATE 10 // (mm/s) Unload filament feedrate. This can be pretty fast.
#define FILAMENT_CHANGE_UNLOAD_ACCEL 25 // (mm/s^2) Lower acceleration may allow a faster feedrate.
#define FILAMENT_CHANGE_UNLOAD_LENGTH 100 // (mm) The length of filament for a complete unload.
// For Bowden, the full length of the tube and nozzle.
// For direct drive, the full length of the nozzle.
// Set to 0 for manual unloading.
#define FILAMENT_CHANGE_SLOW_LOAD_FEEDRATE 6 // (mm/s) Slow move when starting load.
#define FILAMENT_CHANGE_SLOW_LOAD_LENGTH 0 // (mm) Slow length, to allow time to insert material.
// 0 to disable start loading and skip to fast load only
#define FILAMENT_CHANGE_FAST_LOAD_FEEDRATE 6 // (mm/s) Load filament feedrate. This can be pretty fast.
#define FILAMENT_CHANGE_FAST_LOAD_ACCEL 25 // (mm/s^2) Lower acceleration may allow a faster feedrate.
#define FILAMENT_CHANGE_FAST_LOAD_LENGTH 0 // (mm) Load length of filament, from extruder gear to nozzle.
//#define ADVANCED_PAUSE_CONTINUOUS_PURGE // Purge continuously up to the purge length until interrupted.
#define ADVANCED_PAUSE_PURGE_FEEDRATE 3 // (mm/s) Extrude feedrate (after loading). Should be slower than load feedrate.
#define ADVANCED_PAUSE_PURGE_LENGTH 50 // (mm) Length to extrude after loading.
// Set to 0 for manual extrusion.
// Filament can be extruded repeatedly from the Filament Change menu
// until extrusion is consistent, and to purge old filament.
#define ADVANCED_PAUSE_RESUME_PRIME 0 // (mm) Extra distance to prime nozzle after returning from park.
//#define ADVANCED_PAUSE_FANS_PAUSE // Turn off print-cooling fans while the machine is paused.
// Filament Unload does a Retract, Delay, and Purge first:
#define FILAMENT_UNLOAD_RETRACT_LENGTH 13 // (mm) Unload initial retract length.
#define FILAMENT_UNLOAD_DELAY 5000 // (ms) Delay for the filament to cool after retract.
#define FILAMENT_UNLOAD_PURGE_LENGTH 8 // (mm) An unretract is done, then this length is purged.
#define PAUSE_PARK_NOZZLE_TIMEOUT 45 // (seconds) Time limit before the nozzle is turned off for safety.
#define FILAMENT_CHANGE_ALERT_BEEPS 10 // Number of alert beeps to play when a response is needed.
#define PAUSE_PARK_NO_STEPPER_TIMEOUT // Enable for XYZ steppers to stay powered on during filament change.
//#define PARK_HEAD_ON_PAUSE // Park the nozzle during pause and filament change.
//#define HOME_BEFORE_FILAMENT_CHANGE // Ensure homing has been completed prior to parking for filament change
//#define FILAMENT_LOAD_UNLOAD_GCODES // Add M701/M702 Load/Unload G-codes, plus Load/Unload in the LCD Prepare menu.
//#define FILAMENT_UNLOAD_ALL_EXTRUDERS // Allow M702 to unload all extruders above a minimum target temp (as set by M302)
#endif
// @section i2cbus
//#define EXPERIMENTAL_I2CBUS
#define I2C_SLAVE_ADDRESS 0 // Set a value from 8 to 127 to act as a slave
// @section extras
//#define CNC_COORDINATE_SYSTEMS
- Auto-report temperatures with M155 S
#define AUTO_REPORT_TEMPERATURES
- Include capabilities in M115 output
#define EXTENDED_CAPABILITIES_REPORT
- Expected Printer Check
- Add the M16 G-code to compare a string to the MACHINE_NAME.
- M16 with a non-matching string causes the printer to halt.
//#define EXPECTED_PRINTER_CHECK
- Disable all Volumetric extrusion options
//#define NO_VOLUMETRICS
#if DISABLED(NO_VOLUMETRICS)
- Volumetric extrusion default state
- Activate to make volumetric extrusion the default method,
- with DEFAULT_NOMINAL_FILAMENT_DIA as the default diameter.
- M200 D0 to disable, M200 Dn to set a new diameter.
//#define VOLUMETRIC_DEFAULT_ON
#endif
//#define NO_WORKSPACE_OFFSETS
#define PROPORTIONAL_FONT_RATIO 1.0
#define FASTER_GCODE_PARSER
- Startup commands
- Execute certain G-code commands immediately after power-on.
//#define STARTUP_COMMANDS “M17 Z”
- G-code Macros
- Add G-codes M810-M819 to define and run G-code macros.
- Macros are not saved to EEPROM.
//#define GCODE_MACROS
#if ENABLED(GCODE_MACROS)
#define GCODE_MACROS_SLOTS 5 // Up to 10 may be used
#define GCODE_MACROS_SLOT_SIZE 50 // Maximum length of a single macro
#endif
- User-defined menu items that execute custom GCode
//#define CUSTOM_USER_MENUS
#if ENABLED(CUSTOM_USER_MENUS)
//#define CUSTOM_USER_MENU_TITLE “Custom Commands”
#define USER_SCRIPT_DONE “M117 User Script Done”
#define USER_SCRIPT_AUDIBLE_FEEDBACK
//#define USER_SCRIPT_RETURN // Return to status screen after a script
#define USER_DESC_1 “Home & UBL Info”
#define USER_GCODE_1 “G28\nG29 W”
#define USER_DESC_2 "Preheat for " PREHEAT_1_LABEL
#define USER_GCODE_2 “M140 S” STRINGIFY(PREHEAT_1_TEMP_BED) “\nM104 S” STRINGIFY(PREHEAT_1_TEMP_HOTEND)
#define USER_DESC_3 "Preheat for " PREHEAT_2_LABEL
#define USER_GCODE_3 “M140 S” STRINGIFY(PREHEAT_2_TEMP_BED) “\nM104 S” STRINGIFY(PREHEAT_2_TEMP_HOTEND)
#define USER_DESC_4 “Heat Bed/Home/Level”
#define USER_GCODE_4 “M140 S” STRINGIFY(PREHEAT_2_TEMP_BED) “\nG28\nG29”
#define USER_DESC_5 “Home & Info”
#define USER_GCODE_5 “G28\nM503”
#endif
// @section develop
- M43 - display pin status, watch pins for changes, watch endstops & toggle LED, Z servo probe test, toggle pins
#define PINS_DEBUGGING
// Enable Marlin dev mode which adds some special commands
#define MARLIN_DEV_MODE
[/code]
