renegadez
(Renegadez)
July 12, 2017, 6:57am
1
MPCNC Modular Electronics Mount
A wildly experimental prototype modular mounting system for the MPCNC power supply and RAMPS 1.4, volts/amps meter panel (blinky lights and such), laser driver and a Raspberry Pi 2 Model B (AstroPrint/Octoprint).
Everything is modular and I'm...
has anyone tried using this Thing??
If so I am wondering if these 3 Panels wire directly to the Ramps 1.4v board?
Panel Volt Meter - 4.5V to 30VDC
Panel Current Meter - 0 to 9.99A
Panel Temperature Meter / -30 to +70 °C
Edit: Forgot Links
That mount was one of the first ones a long time ago, still seems pretty awesome but I have not used it.
The gauges you listed, none of them plug into the ramps each link has a wiring diagram and they are all standalone.
jeffeb3
(Jeffeb3)
July 12, 2017, 9:26am
3
What are you trying to guage with those guages? i.e. what temperature are you interested in? What voltage are you interested in (it would be pretty boring to read the input, it’s not changing in any significant way).
renegadez
(Renegadez)
July 12, 2017, 11:04am
4
Voltage and operating temperature and current of the laser. I want to use.
I believe i was incorrect these should go to the driver board for the laser
