MPCNC Primo 304SS 1m by 1m SKR Pro 1.2
Hello all, I’m working through my MPCNC build, and I figured that I’d share some of the pictures. This was a pandemic lockdown build, so I ended up doing a lot of the work indoors, instead of the shop.
I’m not allowed to post a link to the video…
https://youtu.be/5ZSFEacbn4c
EDIT - Jeffe: Fixed it.
For some reason, attempting to plot with G2/G3 commands using the precompiled dual endstop firmware gives strange results:
Using a Gcode path viewer (online, github), the code should result in a proper image. Here is the plot done using G1 commands instead:
And I can’t attach the gcode file…
G2/G3:
Arc Command GCode
;Marlin Based Gcode
G92 X0 Y0 Z10.00
G90
G0 X.37 Y61.03 Z3.00 F5500.00
G1 Z-.10 F5500.00
G2 X.38 Y62.55 R66.38 F5500.00
X.44 Y63.48 R10.20
X.85 Y66.09 R27.69
X1.51 Y68.57 R24.42
X2.36 Y70.79 R21.14
X3.36 Y72.61 R12.47
X3.86 Y73.31 R15.46
X4.37 Y73.94 R12.51
X4.99 Y74.63 R17.20
X5.85 Y75.50 R52.21
X7.27 Y76.86 R44.48
X8.33 Y77.71 R10.47
X9.40 Y78.34 R8.17
X10.80 Y78.97 R19.06
X11.44 Y79.21 R20.59
X12.03 Y79.40 R13.75
X12.58 Y79.56 R11.83
X13.13 Y79.68 R10.20
X13.71 Y79.76 R4.13
X14.53 Y79.78 R15.28
X15.34 Y79.76 R15.34
X15.90 Y79.68 R3.57
X17.56 Y79.13 R7.94
X19.16 Y78.20 R9.78
X20.73 Y76.87 R12.38
X22.31 Y75.10 R21.74
X22.72 Y74.57 R19.23
X23.09 Y74.05 R16.05
X23.50 Y73.43 R23.86
X24.06 Y72.55 R86.18
X24.75 Y71.43 R135.36
X25.20 Y70.66 R28.57
X25.52 Y70.06 R15.51
X25.80 Y69.47 R12.38
G3 X26.31 Y68.37 R42.54
X26.74 Y67.55 R14.63
X27.10 Y66.97 R9.25
X27.37 Y66.69 R1.06
X27.44 Y66.64 R1.38
X27.54 Y66.58 R3.63
X27.65 Y66.52 R3.82
X27.75 Y66.47 R2.37
G2 X28.17 Y66.22 R2.52
X28.79 Y65.73 R15.26
X29.57 Y65.07 R23.08
X30.50 Y64.20 R55.45
G3 X31.07 Y63.67 R69.55
X31.54 Y63.25 R30.80
X31.92 Y62.93 R22.74
X32.13 Y62.77 R2.14
X32.21 Y62.73 R.60
X32.26 Y62.72 R.10
X32.32 Y62.74 R.17
X32.45 Y62.82 R3.21
X32.83 Y63.16 R2.00
X33.45 Y63.92 R23.27
X34.06 Y64.72 R39.05
X34.15 Y64.98 R.43
X34.11 Y65.10 R.24
X33.84 Y65.53 R25.03
X33.43 Y66.14 R27.93
X32.77 Y67.09 R164.99
G2 X31.43 Y69.08 R52.04
X30.72 Y70.43 R9.06
X30.37 Y71.63 R5.43
X30.24 Y73.06 R9.19
Y73.45 R20.71
X30.25 Y73.66 R1.98
X30.28 Y73.81 R.84
X30.34 Y73.96 R1.05
X30.50 Y74.22 R1.57
X30.78 Y74.57 R7.05
X31.11 Y74.93 R7.35
X31.41 Y75.21 R4.12
X33.73 Y76.65 R9.93
X37.35 Y78.06 R38.60
X41.75 Y79.29 R49.72
X46.58 Y80.22 R66.83
X48.26 Y80.45 R47.88
X50.24 Y80.66 R90.07
X52.28 Y80.84 R93.49
X54.13 Y80.95 R63.92
X54.86 Y80.97 R27.35
X55.39 Y80.96 R7.99
X55.81 Y80.93 R4.59
X56.15 Y80.85 R2.37
G1 X56.22 Y80.83 Z-.10 F5510.00
G1 X56.28 Y80.82 Z-.10 F5510.00
G1 X56.33 Y80.80 Z-.10 F5510.00
G1 X56.22 Y80.91 Z-.10 F5510.00
G1 X56.09 Y81.04 Z-.10 F5510.00
G1 X55.94 Y81.19 Z-.10 F5510.00
G2 X55.64 Y81.49 R6.20
X55.44 Y81.75 R2.22
X55.31 Y82.00 R1.55
X55.23 Y82.27 R1.55
G3 X55.09 Y82.51 R.48
X54.86 Y82.63 R.43
X54.36 Y82.67 R3.53
X52.60 Y82.71 R282.34
G2 X50.09 Y82.78 R92.07
X48.12 Y82.92 R35.75
X46.36 Y83.15 R27.75
X44.53 Y83.50 R34.24
X41.14 Y84.42 R37.75
X37.21 Y85.80 R74.31
X33.17 Y87.48 R80.89
X29.39 Y89.31 R68.05
X26.47 Y90.92 R74.68
X23.69 Y92.62 R69.18
X21.21 Y94.32 R59.75
X19.23 Y95.87 R29.94
X17.63 Y97.32 R36.79
X15.56 Y99.37 R122.36
X13.49 Y101.51 R123.68
X11.90 Y103.27 R50.27
X11.45 Y103.83 R17.13
X11.08 Y104.33 R9.69
X10.77 Y104.80 R7.90
X10.52 Y105.29 R6.95
X10.31 Y105.79 R4.25
X10.26 Y106.16 R1.05
X10.34 Y106.45 R.59
X10.57 Y106.69 R.78
X10.76 Y106.78 R.70
X10.92 R.27
X11.11 Y106.67 R.59
X11.41 Y106.41 R5.96
G3 X11.48 Y106.34 R2.06
X11.55 Y106.29 R1.07
X11.60 Y106.25 R1.15
X11.62 R.01
Y106.27 R.02
X11.57 Y106.38 R5.99
X11.51 Y106.51 R3.21
X11.43 Y106.65 R6.08
G2 X11.24 Y107.00 R6.31
X11.12 Y107.29 R2.61
X11.06 Y107.51 R1.70
X11.09 Y107.61 R.11
X11.21 Y107.65 R.15
X11.61 Y107.61 R8.57
X12.15 Y107.52 R8.89
X12.83 Y107.37 R23.96
G3 X13.40 Y107.25 R16.32
X13.88 Y107.18 R8.22
X14.25 Y107.14 R8.17
X14.28 Y107.19 R.03
X14.25 Y107.21 R.07
X14.13 Y107.26 R4.34
X13.98 Y107.32 R3.40
X13.81 Y107.37 R5.52
G2 X12.88 Y107.67 R40.19
X12.21 Y107.92 R11.95
X11.54 Y108.21 R12.12
X10.65 Y108.65 R42.24
X9.19 Y109.44 R29.44
X7.97 Y110.21 R17.32
X7.05 Y110.92 R13.18
X6.65 Y111.44 R1.56
X6.56 Y111.69 R1.15
X6.53 Y111.96 R1.17
X6.57 Y112.23 R1.12
X6.66 Y112.46 R.94
X6.80 Y112.66 R1.49
X6.98 Y112.84 R1.70
X7.17 Y112.99 R1.66
X7.37 Y113.10 R1.30
X7.76 Y113.25 R4.84
X8.43 Y113.46 R37.02
X9.27 Y113.71 R49.81
X10.27 Y114.00 R96.00
G3 X11.41 Y114.32 R154.24
X12.13 Y114.54 R26.15
X12.61 Y114.71 R11.64
X12.95 Y114.85 R3.15
G2 X13.09 Y114.92 R2.89
X13.29 Y115.01 R10.28
X13.51 Y115.10 R11.26
X13.72 Y115.17 R8.50
G3 X14.13 Y115.33 R20.10
X14.35 Y115.43 R2.19
X14.46 Y115.50 R.51
Y115.56 R.04
X14.42 Y115.58 R.07
X14.33 R.71
X14.20 Y115.56 R1.31
X14.02 Y115.53 R4.87
G2 X13.43 Y115.41 R74.21
X13.18 Y115.37 R3.13
X13.02 Y115.36 R.83
X12.86 Y115.39 R.71
X12.78 Y115.42 R.66
X12.68 Y115.47 R1.45
X12.58 Y115.53 R1.49
X12.51 Y115.59 R.85
X12.42 Y115.67 R1.35
X12.38 Y115.72 R.24
X12.36 Y115.78 R.13
X12.37 Y115.84 R.19
X12.47 Y116.03 R.61
X12.88 Y116.55 R36.08
X13.48 Y117.28 R42.45
X14.37 Y118.35 R195.65
G3 X15.78 Y120.04 R153.67
X16.82 Y121.34 R51.48
X17.71 Y122.54 R39.87
X18.65 Y123.90 R58.88
G1 X19.44 Y125.08 Z-.10 F5510.00
G1 X19.15 Y125.60 Z-.10 F5510.00
G2 X18.92 Y126.04 R7.52
X18.77 Y126.41 R3.39
X18.67 Y126.79 R3.08
X18.59 Y127.23 R5.22
X18.57 Y127.94 R4.42
X18.65 Y128.73 R6.76
X18.85 Y129.69 R10.83
X19.20 Y130.94 R32.71
G3 X19.34 Y131.39 R84.44
X19.45 Y131.77 R43.23
G1 X19.54 Y132.11 Z-.10 F5510.00
G3 Y132.13 R.01
G1 X19.29 Y132.10 Z-.10 F5510.00
G3 X19.03 Y132.07 R22.97
X18.73 Y132.02 R44.05
G2 X17.07 Y131.81 R50.77
X16.00 Y131.75 R9.37
X15.24 Y131.82 R4.25
X14.64 Y132.04 R2.03
X14.36 Y132.23 R1.41
X14.01 Y132.58 R5.96
X13.67 Y132.98 R6.38
X13.40 Y133.36 R4.07
X12.77 Y134.69 R6.67
X12.28 Y136.46 R16.08
X11.87 Y138.79 R27.23
X11.53 Y141.90 R81.26
X11.38 Y143.54 R206.98
X11.30 Y144.75 R62.91
X11.25 Y145.72 R38.32
X11.23 Y146.60 R24.90
X11.24 Y147.56 R33.23
X11.30 Y148.00 R1.93
X11.45 Y148.31 R.92
X11.77 Y148.68 R3.27
X12.11 Y148.98 R3.81
X12.43 Y149.18 R2.08
X12.74 Y149.31 R1.58
X13.06 Y149.35 R1.19
X13.65 Y149.28 R2.50
X14.74 Y148.99 R26.15
X15.82 Y148.64 R24.13
X16.48 Y148.35 R4.23
G3 X16.66 Y148.26 R3.77
X16.81 Y148.20 R1.37
X16.94 Y148.16 R.90
X17.06 Y148.15 R.66
X17.23 Y148.17 R.79
X17.37 Y148.22 R.51
X17.47 Y148.30 R.33
X17.50 Y148.40 R.15
X17.46 Y148.53 R.24
X17.23 Y148.85 R8.81
X16.89 Y149.28 R12.01
X16.37 Y149.90 R51.87
G2 X14.68 Y152.10 R28.05
X13.48 Y154.17 R15.43
X12.66 Y156.29 R13.84
X12.13 Y158.68 R18.27
X11.91 Y161.82 R19.46
X12.19 Y165.01 R20.81
X12.93 Y167.99 R19.22
X14.09 Y170.50 R12.66
X14.81 Y171.53 R9.66
X15.63 Y172.42 R8.33
X16.48 Y173.09 R6.85
X17.28 Y173.48 R3.11
X17.51 Y173.53 R1.22
X17.77 Y173.54 R1.99
X18.04 Y173.52 R2.02
X18.28 Y173.46 R1.34
X18.91 Y173.12 R2.26
X19.59 Y172.51 R5.83
X20.21 Y171.75 R6.55
X20.67 Y170.94 R5.22
X20.95 Y170.25 R8.11
X21.21 Y169.43 R13.67
X21.54 Y168.21 R37.28
X22.10 Y165.93 R383.89
G3 X22.59 Y163.97 R101.20
X23.10 Y162.11 R83.98
X23.59 Y160.50 R68.46
X23.99 Y159.35 R19.40
X24.47 Y158.14 R48.04
X24.95 Y157.05 R33.06
X25.38 Y156.15 R42.71
X25.57 Y155.90 R.75
X25.66 Y155.86 R.20
X25.73 Y155.88 R.09
X25.78 Y155.95 R.14
X25.80 Y156.08 R.48
X25.77 Y156.29 R.87
X25.68 Y156.61 R4.17
X25.51 Y157.06 R9.43
X25.21 Y157.78 R56.06
G2 X24.69 Y159.09 R46.38
X24.33 Y160.13 R17.21
X24.11 Y160.95 R10.52
X24.04 Y161.55 R2.87
X24.07 Y161.90 R1.89
X24.16 Y162.27 R2.36
X24.36 Y162.74 R5.21
X24.73 Y163.51 R35.60
X25.41 Y164.78 R22.19
X26.08 Y165.82 R12.43
X26.85 Y166.78 R12.02
X27.81 Y167.78 R19.49
X29.79 Y169.40 R14.56
X32.01 Y170.63 R13.94
X34.06 Y171.29 R10.84
X35.43 Y171.13 R2.10
X35.72 Y170.95 R2.03
X35.99 Y170.73 R2.44
X36.20 Y170.49 R2.15
X36.33 Y170.26 R.83
X36.41 Y169.89 R1.44
X36.44 Y169.26 R10.27
X36.43 Y168.55 R10.99
X36.38 Y167.88 R8.89
X36.18 Y166.57 R20.58
X35.87 Y165.07 R36.63
X35.44 Y163.35 R49.61
X34.88 Y161.34 R92.95
G3 X34.48 Y159.96 R142.24
X34.23 Y158.99 R33.88
X34.05 Y158.20 R20.44
X33.90 Y157.40 R20.62
X33.84 Y157.07 R52.86
X33.80 Y156.78 R27.36
G1 X33.76 Y156.53 Z-.10 F5510.00
G3 Y156.52 R.01
G1 X33.78 Y156.52 Z-.10 F5510.00
G1 X33.94 Y156.55 Z-.10 F5510.00
G3 X34.12 Y156.60 R10.72
X34.33 Y156.65 R20.52
G2 X35.19 Y156.81 R5.59
X35.97 R3.71
X36.83 Y156.64 R4.74
X37.90 Y156.27 R13.38
X38.61 Y155.96 R13.04
X39.53 Y155.52 R37.48
X40.41 Y155.07 R38.16
X40.95 Y154.75 R6.93
X41.37 Y154.43 R4.79
X41.80 Y154.05 R6.59
X42.16 Y153.66 R6.10
X42.41 Y153.31 R2.50
X42.85 Y152.38 R5.76
X43.20 Y151.26 R9.94
X43.47 Y149.86 R14.84
X43.67 Y148.10 R35.57
X43.74 Y147.30 R39.48
X43.80 Y146.39 R64.32
X43.84 Y145.55 R61.32
X43.85 Y144.98 R13.49
G1 X43.85 Y144.52 Z-.10 F5510.00
G1 X44.99 Y144.23 Z-.10 F5510.00
G2 X46.36 Y143.85 R42.38
X47.37 Y143.51 R13.85
X48.29 Y143.12 R11.47
X49.32 Y142.58 R21.38
G1 X50.18 Y142.11 Z-.10 F5510.00
G1 X50.95 Y142.30 Z-.10 F5510.00
G2 X51.27 Y142.38 R19.22
X51.61 Y142.45 R21.15
X51.90 Y142.51 R18.86
X52.10 Y142.55 R3.64
X53.23 Y142.66 R15.27
X54.82 Y142.74 R55.11
X56.63 Y142.79 R66.75
X58.50 Y142.78 R76.77
X59.94 Y142.75 R121.56
X60.96 Y142.71 R31.46
X61.78 Y142.65 R19.00
X62.58 Y142.55 R16.65
G1 X62.90 Y142.50 Z-.10 F5510.00
G1 X63.38 Y142.43 Z-.10 F5510.00
G1 X63.90 Y142.35 Z-.10 F5510.00
G1 X64.40 Y142.27 Z-.10 F5510.00
G2 X65.34 Y142.12 R29.78
X65.92 Y141.98 R5.05
X66.30 Y141.82 R2.12
X66.54 Y141.62 R.77
X66.60 Y141.54 R1.21
X66.62 Y141.49 R.11
X66.61 Y141.44 R.10
X66.57 Y141.35 R1.11
X66.50 Y141.27 R.41
X66.35 Y141.11 R7.63
X66.15 Y140.93 R7.72
X65.94 Y140.75 R10.22
G3 X65.73 Y140.57 R38.61
X65.56 Y140.42 R20.14
G1 X65.41 Y140.28 Z-.10 F5510.00
G3 X65.40 Y140.27 R.02
X65.44 R.63
X65.48 Y140.29 R.63
X65.54 Y140.31 R1.34
G1 X65.62 Y140.34 Z-.10 F5510.00
G1 X65.80 Y140.41 Z-.10 F5510.00
G1 X66.02 Y140.49 Z-.10 F5510.00
G1 X66.25 Y140.57 Z-.10 F5510.00
G3 X67.28 Y140.97 R43.86
X68.37 Y141.43 R58.68
X69.52 Y141.93 R65.47
X70.70 Y142.48 R77.49
G2 X71.89 Y143.02 R54.78
X72.63 Y143.30 R8.04
X73.14 Y143.42 R3.17
X73.52 Y143.40 R.89
X73.80 Y143.26 R.88
X73.98 Y143.05 R.54
X74.08 Y142.68 R1.27
X74.13 Y142.00 R11.15
Y141.27 R5.83
X74.03 Y140.50 R7.28
X73.84 Y139.68 R8.57
X73.55 Y138.80 R12.50
G3 X73.50 Y138.64 R9.64
X73.45 Y138.49 R6.30
X73.41 Y138.36 R7.95
X73.40 Y138.32 R.15
X73.42 Y138.29 R.03
X73.48 Y138.27 R.21
X73.58 Y138.26 R.68
X73.75 R4.52
G2 X73.94 Y138.27 R4.57
X74.05 Y138.25 R.52
X74.14 Y138.22 R.27
X74.22 Y138.16 R.53
X74.38 Y137.93 R.73
X74.47 Y137.62 R1.13
X74.51 Y137.13 R3.72
X74.52 Y136.15 R48.54
G3 Y135.63 R107.62
Y135.19 R50.37
G1 X74.52 Y134.83 Z-.10 F5510.00
G3 X74.54 Y134.86 R.30
G1 X74.60 Y135.15 Z-.10 F5510.00
G1 X74.67 Y135.48 Z-.10 F5510.00
G1 X74.75 Y135.86 Z-.10 F5510.00
G2 X75.04 Y137.14 R25.39
X75.31 Y137.58 R.87
X75.66 Y137.60 R.28
X76.20 Y137.14 R3.17
X76.58 Y136.66 R3.42
X76.94 Y136.04 R6.28
X77.29 Y135.25 R9.25
X77.65 Y134.25 R20.93
X78.10 Y132.73 R23.55
X78.50 Y131.04 R34.43
X78.83 Y129.21 R39.28
X79.10 Y127.27 R47.28
X79.22 Y126.06 R43.30
X79.29 Y125.04 R21.13
X79.31 Y123.77 R38.75
X79.32 Y121.52 R342.48
X79.30 Y118.83 R215.20
X79.25 Y116.71 R84.01
X79.15 Y114.86 R61.95
X79.00 Y113.00 R62.46
G3 X78.85 Y111.33 R66.23
X78.90 Y110.68 R2.18
X79.14 Y110.36 R.49
X79.64 Y110.20 R1.29
G2 X80.01 Y110.13 R2.08
X80.32 Y110.00 R1.46
X80.65 Y109.77 R2.10
X81.05 Y109.40 R7.42
X81.46 Y108.95 R6.14
X81.71 Y108.57 R1.92
X81.86 Y108.14 R1.99
X81.97 Y107.53 R6.98
X82.07 Y105.81 R11.12
X81.91 Y104.07 R11.59
X81.47 Y102.26 R13.58
X80.74 Y100.28 R21.98
X80.30 Y99.30 R21.46
X79.79 Y98.32 R24.89
X79.26 Y97.40 R23.03
X78.76 Y96.63 R12.91
X78.03 Y95.67 R17.78
X77.18 Y94.68 R23.88
X76.01 Y93.43 R45.50
X74.20 Y91.60 R225.32
G3 X72.51 Y89.90 R352.81
X71.43 Y88.78 R67.88
X70.63 Y87.91 R34.68
X69.93 Y87.08 R24.72
G2 X68.67 Y85.65 R20.26
X67.43 Y84.54 R11.77
X66.14 Y83.70 R9.85
X64.75 Y83.07 R9.58
G3 X64.18 Y82.85 R11.64
X63.82 Y82.67 R2.29
X63.62 Y82.49 R.90
X63.55 Y82.30 R.29
X63.61 Y81.70 R3.20
X63.87 Y80.41 R55.04
X64.21 Y78.96 R50.05
X64.58 Y77.59 R41.75
G2 X64.75 Y76.99 R59.05
X64.94 Y76.26 R124.99
X65.14 Y75.52 R125.95
X65.30 Y74.90 R64.10
X65.73 Y73.07 R72.43
X65.94 Y71.87 R13.60
X66.02 Y70.81 R9.41
X66.00 Y69.52 R20.43
X65.98 Y69.03 R42.48
X65.94 Y68.49 R59.40
X65.91 Y67.99 R54.79
X65.87 Y67.62 R16.70
X65.82 Y67.11 R28.04
X65.76 Y66.71 R10.78
X65.69 Y66.25 R15.20
X65.55 Y65.54 R90.40
G3 X65.47 Y65.06 R14.91
X65.48 Y64.91 R.29
X65.57 Y64.86 R.07
X65.79 Y64.94 R1.22
X65.91 Y65.01 R1.52
X66.09 Y65.13 R8.48
X66.30 Y65.26 R9.55
X66.50 Y65.40 R8.98
G2 X66.95 Y65.71 R17.33
X67.35 Y65.96 R9.41
X67.78 Y66.20 R10.16
X68.31 Y66.48 R23.13
G1 X68.96 Y66.81 Z-.10 F5510.00
G1 X66.91 Y68.79 Z-.10 F5510.00
G1 X66.88 Y70.53 Z-.10 F5510.00
G3 X66.78 Y72.75 R39.68
X66.56 Y74.57 R18.39
X66.19 Y76.13 R13.84
X65.66 Y77.59 R11.93
G2 X65.45 Y78.06 R15.13
X65.31 Y78.45 R6.38
X65.22 Y78.76 R4.39
X65.21 Y78.94 R.49
X65.22 Y79.01 R.41
X65.25 Y79.05 R.09
X65.30 Y79.08 R.11
X65.39 Y79.09 R.67
X66.70 Y78.65 R1.71
X70.05 Y75.45 R107.61
X73.34 Y71.92 R66.94
X75.70 Y68.80 R29.04
X76.16 Y68.03 R12.24
X76.53 Y67.29 R8.94
X76.78 Y66.63 R6.92
X76.85 Y66.17 R1.51
X76.82 Y65.93 R1.10
X76.74 Y65.65 R2.18
X76.61 Y65.34 R2.84
X76.42 Y65.02 R4.37
X75.30 Y63.59 R8.41
X73.72 Y62.18 R15.19
X71.34 Y60.51 R32.52
X67.47 Y58.12 R179.99
G1 X66.58 Y57.58 Z-.10 F5510.00
G1 X66.51 Y56.30 Z-.10 F5510.00
G2 X66.43 Y55.08 R33.84
X66.32 Y54.41 R3.68
X66.10 Y53.90 R2.00
X65.70 Y53.35 R4.66
G3 X65.56 Y53.17 R9.79
X65.41 Y52.98 R10.84
X65.29 Y52.81 R9.66
X65.21 Y52.70 R1.90
X65.13 Y52.55 R1.30
X65.10 Y52.42 R.50
X65.08 Y52.24 R1.25
Y51.83 R25.46
X65.09 Y51.52 R9.19
X65.11 Y51.25 R5.15
X65.14 Y51.02 R3.85
X65.18 Y50.83 R2.11
G1 X65.28 Y50.48 Z-.10 F5510.00
G1 X65.47 Y50.49 Z-.10 F5510.00
G3 X65.58 Y50.51 R.62
X65.80 Y50.57 R7.76
X66.06 Y50.65 R8.32
X66.32 Y50.75 R10.11
G2 X67.35 Y51.09 R16.80
X68.06 Y51.22 R3.39
X68.64 Y51.18 R1.97
X69.23 Y50.97 R2.70
X69.66 Y50.70 R2.15
X69.93 Y50.37 R1.12
X70.08 Y49.94 R1.32
X70.12 Y49.35 R3.59
X70.09 Y48.89 R4.03
X70.00 Y48.42 R4.66
X69.86 Y47.91 R6.03
X69.64 Y47.30 R12.22
X69.09 Y46.07 R14.64
X68.48 Y45.01 R10.13
X67.73 Y44.01 R10.52
X66.78 Y42.97 R17.04
X66.24 Y42.46 R19.36
X65.76 Y42.04 R10.51
X65.29 Y41.68 R8.78
X64.80 Y41.35 R9.01
G3 X64.61 Y41.23 R5.81
X64.41 Y41.09 R6.13
X64.25 Y40.97 R5.43
X64.15 Y40.88 R.98
X64.05 Y40.76 R1.56
X64.00 Y40.68 R.32
X63.98 Y40.58 R.36
Y40.41 R2.30
X64.02 Y40.11 R1.05
X64.15 Y39.76 R2.55
X64.41 Y39.26 R6.61
X64.89 Y38.43 R51.66
G2 X65.31 Y37.71 R35.41
X65.67 Y37.05 R22.32
X65.95 Y36.51 R21.31
X66.03 Y36.26 R1.05
X66.02 Y36.09 R.33
X65.94 Y35.91 R.70
X65.75 Y35.69 R1.68
X65.43 Y35.37 R9.35
X65.02 Y35.00 R9.03
X64.55 Y34.63 R12.51
X64.00 Y34.23 R16.20
X63.35 Y33.79 R29.91
X61.68 Y32.78 R26.70
X59.93 Y31.88 R27.09
X57.96 Y31.05 R32.63
X55.63 Y30.20 R59.44
G3 X55.10 Y30.02 R80.80
X54.66 Y29.87 R44.01
G1 X54.27 Y29.73 Z-.10 F5510.00
G3 X54.23 Y29.70 R.11
X54.20 Y29.59 R.13
X54.29 Y29.08 R17.56
X54.42 Y28.53 R10.03
X54.58 Y27.97 R10.16
X55.22 Y26.26 R24.15
X56.01 Y24.51 R28.85
X56.80 Y23.01 R31.17
X57.31 Y22.44 R1.76
X57.48 Y22.36 R.51
X57.70 Y22.33 R.97
X57.95 Y22.35 R1.27
X58.23 Y22.42 R1.87
X58.91 Y22.69 R9.47
X60.07 Y23.20 R74.46
X61.58 Y23.90 R110.53
X63.48 Y24.80 R280.65
G2 X66.23 Y26.10 R229.68
X68.40 Y27.07 R85.60
X70.21 Y27.81 R56.30
X71.85 Y28.40 R35.62
X74.15 Y29.04 R22.78
X76.07 Y29.27 R9.99
X77.93 Y29.13 R9.11
X80.03 Y28.60 R16.32
X81.04 Y28.17 R6.72
X82.13 Y27.53 R11.83
X83.25 Y26.71 R13.92
X84.33 Y25.75 R16.48
G3 X84.68 Y25.41 R18.15
X85.03 Y25.10 R15.61
X85.34 Y24.84 R12.85
X85.58 Y24.66 R3.48
G2 X86.73 Y23.71 R8.18
X87.74 Y22.53 R9.41
X88.55 Y21.18 R9.73
X89.13 Y19.73 R9.59
X89.21 Y19.44 R4.66
X89.25 Y19.20 R1.77
X89.27 Y18.91 R3.39
Y18.35 R40.40
X89.26 Y17.67 R16.19
X89.21 Y17.15 R5.82
X89.12 Y16.62 R6.41
X88.95 Y15.90 R22.61
X88.79 Y15.33 R11.88
X88.61 Y14.80 R9.89
X88.42 Y14.31 R8.91
X88.20 Y13.86 R6.97
X87.77 Y13.14 R7.19
X87.22 Y12.42 R10.24
X86.43 Y11.52 R19.74
X85.19 Y10.21 R96.82
X84.19 Y9.20 R99.69
X83.35 Y8.37 R48.99
X82.66 Y7.72 R34.10
X82.17 Y7.32 R6.90
X81.17 Y6.73 R5.05
X79.75 Y6.20 R13.88
X78.06 Y5.76 R17.87
X76.19 Y5.45 R24.48
X75.31 Y5.36 R12.73
X74.17 Y5.31 R33.72
X73.06 Y5.30 R33.53
X72.27 Y5.35 R8.91
X69.54 Y5.75 R27.99
X66.84 Y6.42 R29.26
X64.28 Y7.32 R27.83
X61.98 Y8.42 R21.40
X60.49 Y9.32 R25.15
X59.12 Y10.29 R21.50
X57.79 Y11.39 R23.06
X56.40 Y12.70 R34.03
X55.16 Y14.04 R23.69
X54.22 Y15.28 R12.29
X53.28 Y16.87 R19.94
X51.91 Y19.53 R124.60
G3 X51.52 Y20.29 R103.00
X51.11 Y21.08 R126.15
X50.73 Y21.80 R113.71
X50.46 Y22.30 R27.40
X49.66 Y23.70 R60.74
X48.38 Y25.83 R324.86
X47.03 Y28.07 R950.62
X46.75 Y28.46 R3.01
X46.43 Y28.75 R1.50
X46.03 Y28.94 R1.66
X45.41 Y29.09 R4.65
X44.21 Y29.30 R52.83
G2 X42.97 Y29.51 R49.79
X41.96 Y29.72 R23.04
X40.87 Y29.99 R29.19
X39.33 Y30.42 R114.39
G3 X38.55 Y30.65 R136.29
X37.88 Y30.83 R70.01
G1 X37.29 Y30.99 Z-.10 F5510.00
G3 X37.27 Y30.98 R.03
X37.25 Y30.96 R.04
G1 X37.27 Y30.27 Z-.10 F5510.00
G3 X37.29 Y29.50 R104.53
X37.32 Y28.59 R202.56
X37.42 Y25.69 R939.96
X37.51 Y23.80 R178.31
X37.59 Y22.29 R102.41
X37.70 Y20.70 R122.94
G2 X37.92 Y17.48 R193.26
X38.05 Y14.64 R115.84
X38.11 Y12.33 R120.57
X38.02 Y11.43 R4.04
X37.77 Y10.71 R3.03
X37.32 Y9.94 R5.61
X36.61 Y9.07 R9.21
X35.59 Y8.02 R26.45
X34.29 Y6.82 R30.60
X32.97 Y5.75 R26.06
X31.56 Y4.74 R27.32
X29.97 Y3.74 R37.62
X28.50 Y2.90 R40.48
X27.11 Y2.20 R29.20
X25.74 Y1.60 R26.56
X24.35 Y1.08 R26.26
X23.42 Y.80 R12.30
X22.60 Y.64 R6.57
X21.62 Y.57 R10.18
X20.10 Y.55 R56.00
X18.58 Y.57 R51.04
X17.59 Y.65 R9.89
X16.76 Y.82 R6.48
X15.83 Y1.11 R11.72
G3 X15.18 Y1.33 R17.07
X14.61 Y1.49 R10.17
X14.06 Y1.61 R9.08
X13.47 Y1.70 R10.60
G2 X12.31 Y1.89 R19.15
X10.91 Y2.18 R40.27
X9.59 Y2.51 R40.12
X8.77 Y2.78 R7.29
X8.19 Y3.03 R11.14
X7.57 Y3.33 R15.28
X7.02 Y3.64 R14.01
X6.64 Y3.89 R3.82
X5.46 Y4.89 R13.47
X4.30 Y6.09 R18.18
X3.36 Y7.26 R16.85
X2.95 Y8.10 R2.72
X2.70 Y9.40 R6.99
X2.47 Y12.10 R96.77
X2.32 Y14.80 R99.09
X2.40 Y16.08 R6.40
X2.88 Y17.58 R5.30
X3.83 Y19.11 R8.95
X5.19 Y20.57 R10.96
X6.88 Y21.86 R14.22
X7.98 Y22.51 R13.36
X9.12 Y23.04 R11.96
X10.33 Y23.45 R12.66
X11.68 Y23.78 R17.15
X12.64 Y23.95 R22.99
X13.48 Y24.05 R12.36
X14.37 Y24.10 R14.64
X15.55 Y24.11 R42.61
X18.31 Y23.99 R32.86
X20.69 Y23.63 R18.89
X23.04 Y22.96 R19.77
X25.75 Y21.90 R39.05
G3 X27.66 Y21.11 R54.55
X29.37 Y20.49 R33.04
X30.82 Y20.03 R52.86
X31.01 Y20.16 R.15
X30.92 Y21.13 R2.83
X30.08 Y24.10 R167.96
X29.05 Y27.49 R118.80
X27.87 Y30.97 R137.01
X27.13 Y33.05 R193.06
X26.72 Y34.06 R14.19
X26.37 Y34.69 R4.60
X25.95 Y35.20 R3.14
X25.73 Y35.40 R3.94
X25.49 Y35.59 R4.19
X25.20 Y35.79 R5.78
X24.82 Y36.02 R14.67
G2 X22.42 Y37.51 R96.57
X20.21 Y38.97 R75.36
X18.32 Y40.33 R60.60
X16.91 Y41.47 R22.51
X15.83 Y42.46 R38.38
X14.63 Y43.64 R66.59
X13.49 Y44.80 R64.23
X12.62 Y45.77 R26.06
X12.40 Y46.03 R10.00
X12.14 Y46.37 R25.31
X11.87 Y46.72 R26.42
X11.64 Y47.04 R15.77
G1 X11.13 Y47.76 Z-.10 F5510.00
G1 X9.80 Y47.74 Z-.10 F5510.00
G2 X8.07 R44.10
X6.99 Y47.85 R7.51
X6.18 Y48.08 R3.90
X5.41 Y48.48 R4.35
X4.76 Y49.00 R5.09
X4.01 Y49.75 R13.52
X3.30 Y50.59 R14.12
X2.75 Y51.37 R8.13
X1.98 Y52.87 R12.05
X1.32 Y54.62 R18.39
X.81 Y56.56 R20.88
X.47 Y58.60 R23.77
X.40 Y59.51 R9.58
X.37 Y61.03 R66.94
G0 Z3.00 F5510.00
G0 X59.21 Y51.63 F5510.00
G1 Z-.10 F300.00
G2 X59.23 Y51.76 R.54 F5510.00
X59.30 Y51.93 R1.14
X59.46 Y52.26 R16.13
X59.76 Y52.80 R13.16
X60.06 Y53.29 R10.08
X60.34 Y53.70 R15.81
X60.44 Y53.75 R.13
X60.46 R.05
G1 X60.76 Y53.60 Z-.10 F5510.00
G2 X61.10 Y53.45 R62.62
X61.50 Y53.26 R119.03
G3 X62.21 Y52.92 R38.42
X62.71 Y52.71 R8.54
X63.10 Y52.58 R4.63
X63.47 Y52.50 R3.35
G2 X63.88 Y52.30 R.78
X64.10 Y51.92 R.74
X64.20 Y51.12 R4.32
X64.25 Y48.98 R149.66
G3 X64.27 Y48.03 R195.15
X64.29 Y47.20 R110.23
G1 X64.31 Y46.49 Z-.10 F5510.00
G3 X64.33 Y46.39 R.51
X64.41 Y46.34 R.06
X64.52 Y46.45 R.21
X64.67 Y46.84 R2.86
X64.88 Y47.53 R21.61
G2 X65.14 Y48.38 R14.98
X65.38 Y48.88 R2.50
X65.69 Y49.26 R1.71
X66.18 Y49.64 R4.41
X66.69 Y49.95 R5.23
X67.21 Y50.17 R3.99
X67.71 Y50.30 R3.45
X68.20 Y50.35 R2.62
X68.53 Y50.33 R2.63
X68.75 Y50.26 R.69
X68.91 Y50.13 R.52
X69.05 Y49.93 R1.05
X69.19 Y48.84 R1.67
X68.67 Y47.15 R9.82
X67.75 Y45.35 R11.55
X66.58 Y43.86 R9.11
X65.77 Y43.11 R9.72
X64.86 Y42.44 R10.82
X64.00 Y41.94 R9.48
X63.40 Y41.76 R1.66
X63.25 Y41.75 R1.90
X63.17 Y41.77 R.24
X63.09 Y41.81 R.22
X62.99 Y41.91 R1.51
X62.77 Y42.23 R1.38
X62.29 Y43.20 R53.43
X61.79 Y44.28 R38.62
X61.36 Y45.30 R28.95
X60.62 Y47.22 R94.42
X59.92 Y49.15 R92.22
X59.34 Y50.86 R127.76
X59.21 Y51.45 R2.62
Y51.63 R1.42
G0 Z3.00 F5510.00
G0 X61.10 Y54.85 F5510.00
G1 Z-.10 F300.00
G2 X61.14 Y55.07 R.74 F5510.00
X61.25 Y55.37 R2.89
X61.46 Y55.79 R6.51
X61.81 Y56.43 R36.54
G1 X62.30 Y57.29 Z-.10 F5510.00
G1 X62.99 Y56.94 Z-.10 F5510.00
G3 X63.40 Y56.73 R28.78
X63.60 Y56.65 R1.89
X63.75 Y56.62 R.63
X63.90 R.67
X64.01 Y56.64 R.96
X64.17 Y56.68 R4.07
X64.35 Y56.74 R4.55
X64.52 Y56.80 R3.84
G2 X64.95 Y56.94 R3.70
X65.24 Y56.95 R.66
X65.43 Y56.84 R.33
X65.55 Y56.61 R.63
X65.60 Y56.23 R1.44
X65.58 Y55.61 R9.11
X65.52 Y54.97 R8.86
X65.42 Y54.51 R2.80
X65.22 Y54.13 R1.25
X64.90 Y53.79 R1.89
X64.47 Y53.53 R2.12
X64.00 Y53.37 R2.15
X63.37 Y53.33 R2.13
X62.74 Y53.48 R2.52
X62.11 Y53.79 R2.97
X61.51 Y54.27 R4.19
X61.28 Y54.51 R13.10
X61.17 Y54.64 R1.10
X61.12 Y54.74 R.38
X61.10 Y54.85 R.35
G0 Z3.00 F5510.00
G0 X13.18 Y53.95 F5510.00
G1 Z-.10 F300.00
G2 X13.29 Y54.07 R.47 F5510.00
X13.91 Y54.57 R104.41
X14.55 Y55.05 R40.36
X15.07 Y55.43 R17.61
X16.02 Y56.04 R23.52
X17.10 Y56.69 R36.72
X18.14 Y57.28 R74.12
X18.43 Y57.35 R.59
X18.46 Y57.33 R.04
X18.50 Y57.27 R.90
X18.55 Y57.17 R1.04
X18.60 Y57.06 R1.73
G3 X18.93 Y56.34 R8.79
X19.42 Y55.40 R26.23
X19.97 Y54.46 R27.42
X20.49 Y53.66 R15.69
X21.16 Y52.78 R11.87
X21.85 Y52.05 R8.53
X22.58 Y51.45 R7.34
X23.34 Y50.99 R5.87
X23.88 Y50.74 R6.94
X24.38 Y50.57 R4.59
X24.93 Y50.44 R5.26
X25.61 Y50.35 R11.66
G2 X26.15 Y50.28 R7.51
X26.53 Y50.17 R2.25
X26.87 Y50.01 R1.97
X27.26 Y49.75 R4.73
G3 X27.78 Y49.40 R5.83
X28.41 Y49.05 R10.38
X29.05 Y48.76 R9.96
X29.56 Y48.59 R3.63
X29.90 Y48.53 R3.48
X30.24 Y48.49 R3.47
X30.78 Y48.48 R12.62
X32.08 R320.84
X33.68 Y48.49 R109.17
X34.34 Y48.55 R4.42
X34.88 Y48.70 R2.37
X35.69 Y49.08 R14.61
X37.00 Y49.79 R18.65
X38.19 Y50.59 R15.95
X39.34 Y51.51 R16.79
X40.50 Y52.60 R23.28
X41.44 Y53.61 R21.41
X42.21 Y54.57 R13.61
X42.88 Y55.59 R13.33
X43.53 Y56.77 R19.64
G2 X43.92 Y57.52 R69.46
X44.16 Y57.97 R9.96
X44.34 Y58.25 R6.34
X44.43 Y58.30 R.11
X44.48 Y58.28 R.07
X44.70 Y58.08 R28.87
X44.97 Y57.84 R13.01
X45.26 Y57.56 R23.36
G3 X45.59 Y57.25 R22.35
X45.95 Y56.92 R29.02
X46.28 Y56.63 R26.39
X46.53 Y56.42 R7.13
X48.39 Y55.15 R15.46
X50.53 Y54.08 R19.29
X52.84 Y53.26 R20.31
X55.23 Y52.72 R20.14
X55.65 Y52.67 R8.68
X56.60 Y52.56 R165.47
X57.58 Y52.46 R271.23
X57.84 Y52.45 R2.58
G2 X57.88 Y52.42 R.04
Y52.37 R.07
X57.81 Y52.24 R.88
X57.62 Y51.95 R23.92
X57.34 Y51.55 R7.98
X56.97 Y51.09 R17.78
X56.50 Y50.52 R28.17
X55.88 Y49.80 R75.42
G3 X55.44 Y49.29 R25.38
X55.12 Y48.88 R9.43
X54.89 Y48.56 R7.97
X54.85 Y48.41 R.26
X54.86 Y48.38 R.06
X54.89 Y48.36 R.05
X54.96 Y48.35 R.22
X55.08 Y48.37 R2.45
X55.51 Y48.49 R1.50
X56.12 Y48.81 R7.98
X56.83 Y49.26 R10.57
X57.59 Y49.81 R16.32
G2 X57.82 Y49.98 R10.67
X57.98 Y50.09 R2.47
X58.09 Y50.15 R1.48
X58.12 Y50.14 R.02
G3 X58.17 Y50.02 R4.52
G1 X58.45 Y49.30 Z-.10 F5510.00
G1 X58.82 Y48.33 Z-.10 F5510.00
G1 X59.37 Y46.91 Z-.10 F5510.00
G3 X59.65 Y46.19 R167.80
X59.93 Y45.47 R159.65
X60.18 Y44.86 R143.53
X60.32 Y44.50 R18.55
X61.05 Y42.90 R45.08
X61.91 Y41.14 R70.30
X62.91 Y39.23 R83.68
X64.03 Y37.21 R112.57
G2 X64.23 Y36.86 R59.31
X64.40 Y36.56 R31.83
G1 X64.54 Y36.29 Z-.10 F5510.00
G2 X64.55 Y36.26 R.05
X64.52 Y36.22 R.06
G1 X63.75 Y35.65 Z-.10 F5510.00
G2 X63.03 Y35.13 R69.33
X62.50 Y34.77 R20.61
X59.77 Y33.22 R22.29
X56.73 Y31.98 R26.99
X53.43 Y31.09 R29.17
X49.95 Y30.55 R32.72
X49.13 Y30.49 R12.83
X47.92 Y30.47 R54.92
X46.71 Y30.46 R54.69
X45.85 Y30.50 R14.80
X43.43 Y30.77 R26.85
X41.28 Y31.25 R18.28
X39.09 Y32.01 R20.43
X36.58 Y33.15 R41.38
X34.30 Y34.37 R38.96
X32.50 Y35.56 R19.14
X30.73 Y37.02 R22.40
X28.53 Y39.13 R68.33
X26.95 Y40.74 R98.39
X25.44 Y42.35 R91.58
X23.63 Y44.39 R154.38
X20.97 Y47.43 R702.32
G3 X20.00 Y48.54 R133.76
X19.17 Y49.45 R64.94
X18.44 Y50.23 R48.16
X17.74 Y50.93 R34.14
X16.78 Y51.81 R20.87
X15.96 Y52.44 R8.36
X15.01 Y53.00 R9.80
X13.63 Y53.67 R36.20
G2 X13.43 Y53.77 R6.50
X13.28 Y53.85 R1.98
X13.18 Y53.92 R1.40
Y53.95 R.03
G0 Z3.00 F5510.00
G0 X25.98 Y54.87 F5510.00
G1 Z-.10 F300.00
G2 X25.99 Y55.97 R56.06 F5510.00
X26.03 Y56.56 R5.21
X26.13 Y57.01 R2.64
X26.33 Y57.54 R5.84
X26.72 Y58.32 R7.66
X27.16 Y58.97 R5.07
X27.66 Y59.49 R4.21
X28.21 Y59.89 R3.33
X28.59 Y60.06 R2.00
X29.04 Y60.16 R2.98
X29.49 Y60.20 R2.83
X29.86 Y60.15 R1.39
X30.01 Y60.08 R.52
X30.15 Y59.96 R.86
X30.28 Y59.80 R1.03
X30.38 Y59.61 R1.25
X30.48 Y59.28 R1.63
X30.55 Y58.76 R7.72
X30.62 Y58.04 R14.73
X30.68 Y57.00 R59.37
G3 X30.74 Y55.84 R122.17
X30.79 Y55.03 R30.07
X30.85 Y54.43 R15.91
X30.93 Y53.95 R6.58
X31.01 Y53.62 R3.19
X31.13 Y53.32 R2.68
X31.24 Y53.10 R2.09
X31.31 Y53.09 R.05
X31.34 Y53.14 R.08
X31.36 Y53.42 R21.64
X31.39 Y53.76 R11.53
X31.41 Y54.16 R23.12
G2 X31.46 Y55.19 R144.67
X31.50 Y55.46 R1.49
X31.59 Y55.61 R.28
X31.79 Y55.73 R.85
G3 X32.36 Y56.00 R20.40
X32.90 Y56.27 R16.65
X33.36 Y56.52 R13.48
X33.67 Y56.73 R3.80
G2 X33.83 Y56.83 R16.19
X33.97 Y56.93 R12.65
X34.10 Y57.02 R12.45
X34.15 Y57.05 R.74
X34.39 Y57.14 R.85
X34.80 Y57.21 R6.35
X35.37 Y57.27 R10.88
X36.15 Y57.33 R37.27
G3 X37.39 Y57.43 R31.13
X38.23 Y57.56 R7.02
X38.93 Y57.78 R4.87
X39.71 Y58.13 R8.67
X40.26 Y58.44 R8.48
X40.95 Y58.87 R23.67
X41.63 Y59.34 R23.84
X42.15 Y59.74 R9.75
G2 X42.65 Y60.14 R34.08
X43.10 Y60.48 R21.45
X43.50 Y60.77 R46.87
X43.59 Y60.80 R.14
X43.62 Y60.78 R.03
X43.63 Y60.73 R.21
X43.65 Y60.63 R.60
Y60.49 R3.17
X43.55 Y59.69 R3.14
X43.19 Y58.50 R17.21
X42.70 Y57.23 R18.13
X42.17 Y56.14 R11.62
X40.90 Y54.33 R10.53
X39.06 Y52.48 R20.60
X36.98 Y50.86 R20.78
X35.00 Y49.78 R11.30
X34.18 Y49.48 R8.87
X33.38 Y49.28 R7.23
X32.57 Y49.18 R6.86
X31.76 Y49.17 R6.97
X30.03 Y49.45 R7.81
X28.49 Y50.11 R6.43
X27.23 Y51.11 R5.86
X26.33 Y52.39 R5.33
X26.13 Y52.86 R4.56
X26.03 Y53.25 R1.92
X25.99 Y53.78 R4.25
X25.98 Y54.87 R62.29
G0 Z3.00 F5510.00
G0 X26.08 Y64.40 F5510.00
G1 Z-.10 F300.00
G2 X26.22 Y64.89 R1.37 F5510.00
X26.52 Y65.34 R2.22
X26.85 Y65.55 R.71
X27.25 Y65.56 R.75
X27.78 Y65.37 R2.56
X27.95 Y65.27 R2.38
X28.17 Y65.14 R6.82
X28.39 Y64.98 R7.28
X28.59 Y64.83 R4.83
X29.19 Y64.30 R8.21
X30.34 Y63.17 R105.70
X31.48 Y62.01 R136.11
X31.87 Y61.54 R3.79
X32.06 Y61.25 R4.96
X32.18 Y61.01 R1.64
X32.26 Y60.75 R1.72
X32.33 Y60.38 R5.87
G3 X32.43 Y59.90 R4.99
X32.57 Y59.49 R3.33
X32.77 Y59.07 R3.68
X33.05 Y58.61 R7.35
G2 X33.34 Y58.17 R65.29
X33.47 Y57.96 R4.27
X33.53 Y57.82 R1.22
X33.55 Y57.73 R.25
X33.47 Y57.53 R.28
X32.96 Y57.05 R17.05
X32.42 Y56.59 R10.41
X32.01 Y56.33 R2.52
X31.85 Y56.27 R.68
X31.72 Y56.28 R.25
X31.62 Y56.34 R.20
X31.55 Y56.47 R.40
X31.53 Y56.58 R.52
X31.50 Y56.92 R22.16
X31.47 Y57.32 R18.54
X31.45 Y57.76 R27.52
G3 X31.40 Y58.65 R25.52
X31.32 Y59.26 R5.76
X31.19 Y59.74 R3.42
X31.00 Y60.20 R3.74
X30.74 Y60.59 R1.70
X30.41 Y60.82 R.99
X29.94 Y60.96 R1.75
X29.16 Y61.04 R9.99
G2 X28.83 Y61.07 R11.92
X28.61 Y61.10 R2.71
X28.45 Y61.14 R1.41
X28.32 Y61.19 R.82
X28.08 Y61.35 R1.13
X27.75 Y61.66 R6.99
X27.37 Y62.06 R8.98
X26.98 Y62.53 R13.45
X26.42 Y63.30 R10.53
X26.13 Y63.89 R2.38
X26.08 Y64.40 R1.27
G0 Z3.00 F5510.00
G0 X33.16 Y60.48 F5510.00
G1 Z-.10 F300.00
G2 Y60.97 R6.01 F5510.00
X33.21 Y61.39 R3.48
X33.30 Y61.80 R3.38
X33.45 Y62.24 R5.36
X33.76 Y62.84 R3.80
X34.15 Y63.36 R3.49
X34.57 Y63.73 R2.68
X34.93 Y63.85 R.62
X35.14 Y63.79 R.39
X35.43 Y63.58 R2.56
X35.90 Y63.16 R10.74
X36.99 Y62.13 R246.43
G1 X37.25 Y61.88 Z-.10 F5510.00
G1 X37.59 Y62.00 Z-.10 F5510.00
G3 X38.67 Y62.42 R17.92
X39.45 Y62.82 R6.15
X40.07 Y63.28 R4.51
X40.65 Y63.86 R5.62
X41.11 Y64.47 R6.71
X41.37 Y65.00 R2.38
X41.48 Y65.51 R1.76
X41.43 Y66.07 R2.33
G2 X41.37 Y66.40 R9.35
X41.35 Y66.62 R1.70
X41.36 Y66.76 R.67
X41.41 Y66.82 R.08
X41.58 Y66.85 R.44
X41.97 Y66.84 R9.98
X42.37 Y66.82 R7.68
X42.65 Y66.77 R1.99
X42.79 Y66.73 R2.03
X42.94 Y66.68 R2.98
X43.08 Y66.63 R2.77
X43.18 Y66.57 R.96
X43.55 Y66.28 R1.56
X43.91 Y65.81 R3.79
X44.20 Y65.28 R3.91
X44.35 Y64.79 R2.08
X44.29 Y63.87 R1.88
X43.77 Y62.74 R5.81
X42.90 Y61.53 R8.07
X41.75 Y60.38 R11.60
X40.79 Y59.64 R11.70
X39.81 Y59.04 R9.51
X38.82 Y58.59 R8.53
X37.82 Y58.30 R6.95
X37.53 Y58.25 R4.41
X37.22 Y58.21 R5.90
X36.84 Y58.18 R8.84
X36.35 Y58.17 R24.62
X35.39 R13.44
X34.79 Y58.28 R2.32
X34.32 Y58.52 R1.60
X33.81 Y58.97 R4.11
X33.47 Y59.36 R5.85
X33.29 Y59.65 R1.28
X33.20 Y59.98 R1.25
X33.16 Y60.48 R5.40
G0 Z3.00 F5510.00
G0 X38.65 Y70.52 F5510.00
G1 Z-.10 F300.00
G2 X38.71 Y70.67 R.11 F5510.00
X39.36 Y70.88 R5.01
X41.23 Y71.33 R198.52
X42.28 Y71.56 R40.82
X43.00 Y71.68 R9.17
X43.76 Y71.75 R10.49
X44.99 Y71.80 R63.86
X46.52 Y71.83 R55.50
X48.71 R221.36
G1 X51.06 Y71.81 Z-.10 F5510.00
G2 X51.29 Y71.77 R.61
X51.33 Y71.74 R.11
Y71.71 R.02
X51.26 Y71.68 R.31
X51.04 Y71.61 R13.28
X50.82 Y71.55 R3.60
X50.36 Y71.45 R52.32
X49.81 Y71.33 R54.38
X49.24 Y71.22 R67.46
G1 X47.80 Y70.93 Z-.10 F5510.00
G1 X46.59 Y69.56 Z-.10 F5510.00
G2 X45.73 Y68.58 R399.33
X45.14 Y67.93 R88.68
X44.73 Y67.48 R48.82
X44.49 Y67.24 R5.10
X44.35 Y67.15 R.44
X44.20 Y67.13 R.33
X43.95 Y67.17 R1.69
X43.23 Y67.35 R79.60
G3 X42.60 Y67.51 R30.91
X42.09 Y67.61 R12.88
X41.69 Y67.68 R8.32
X41.41 Y67.70 R2.02
G2 X40.96 Y67.78 R1.37
X40.63 Y67.99 R.82
X40.33 Y68.43 R1.74
X39.98 Y69.25 R13.16
G3 X39.75 Y69.76 R6.11
X39.54 Y70.05 R1.11
X39.26 Y70.23 R.87
X38.84 Y70.38 R2.92
G2 X38.65 Y70.52 R.29
G0 Z3.00 F5510.00
G0 X31.48 Y93.87 F5510.00
G1 Z-.10 F300.00
G2 X31.51 Y94.31 R3.61 F5510.00
X31.59 Y94.66 R1.57
X31.88 Y95.21 R2.22
X32.34 Y95.70 R2.85
X32.97 Y96.14 R3.82
X33.78 Y96.52 R7.41
X34.02 Y96.61 R5.57
X34.29 Y96.70 R8.38
X34.55 Y96.78 R7.84
X34.75 Y96.82 R2.72
X35.37 Y96.90 R4.31
X36.70 Y96.95 R72.00
X38.44 Y96.98 R91.68
X40.63 Y97.00 R224.75
G3 X41.62 R138.10
X42.46 Y97.01 R76.10
X43.16 Y97.03 R95.67
X43.38 Y97.05 R1.54
X43.63 Y97.11 R1.39
X43.78 Y97.22 R.42
X43.87 Y97.37 R.36
X43.90 Y97.60 R.90
G1 X43.90 Y97.85 Z-.10 F5510.00
G1 X42.09 Y99.43 Z-.10 F5510.00
G2 X40.01 Y101.30 R95.87
X38.40 Y102.89 R42.15
X37.05 Y104.37 R31.67
X35.84 Y105.90 R28.83
X34.44 Y108.00 R24.99
X33.37 Y110.09 R18.78
X32.63 Y112.16 R16.41
X32.22 Y114.20 R13.25
X32.15 Y115.13 R10.46
X32.13 Y116.51 R46.65
X32.14 Y117.88 R47.08
X32.21 Y118.78 R9.11
X32.55 Y120.35 R9.62
X33.14 Y121.83 R9.26
X33.95 Y123.13 R8.56
X34.93 Y124.17 R6.54
X35.94 Y124.91 R8.44
X37.03 Y125.48 R8.00
X38.25 Y125.90 R8.87
X39.65 Y126.19 R13.13
X40.45 Y126.26 R6.98
X41.66 Y126.28 R34.75
X42.89 Y126.26 R34.46
X43.73 Y126.18 R8.09
X45.12 Y125.94 R20.51
X46.50 Y125.59 R20.87
X47.87 Y125.15 R21.61
X49.26 Y124.61 R24.27
X50.70 Y123.94 R30.40
X52.11 Y123.20 R30.43
X53.68 Y122.27 R41.67
X55.64 Y121.03 R108.55
G3 X56.23 Y120.65 R132.34
X56.72 Y120.34 R67.22
G1 X57.16 Y120.06 Z-.10 F5510.00
G3 X57.18 R.01
X57.19 Y120.08 R.03
G1 X57.23 Y120.58 Z-.10 F5510.00
G3 X57.28 Y121.14 R93.23
G1 X57.33 Y121.80 Z-.10 F5510.00
G1 Commands GCode
;Project Dot_main_model
;Created by Estlcam version 11 build 11.235
;Machining time about 00:00:26 hours
G90
G92 X0 Y0 Z10.0000
;No. 1: Engraving 130
G00 X14.7669 Y7.2820
G00 Z0.5000
G01 Z0.0000 F1000 S23700
G01 Z-0.1000
G01 X14.5510 Y7.6526 F7000
G01 X14.3550 Y8.0341
G01 X14.1794 Y8.4254
G01 X14.0246 Y8.8254
G01 X13.8912 Y9.2330
G01 X13.7794 Y9.6471
G01 X13.6896 Y10.0665
G01 X13.6221 Y10.4901
G01 X13.5771 Y10.9166
G01 X13.5545 Y11.3450
G01 X13.5546 Y11.7739
G01 X13.5774 Y12.2022
G01 X13.6227 Y12.6287
G01 X13.6904 Y13.0522
G01 X13.7804 Y13.4716
G01 X13.8923 Y13.8856
G01 X14.0027 Y14.1925
G01 X14.1259 Y14.4944
G01 X14.2617 Y14.7908
G01 X14.4099 Y15.0812
G01 X14.5703 Y15.3651
G01 X14.7424 Y15.6420
G01 X14.9262 Y15.9114
G01 X15.1211 Y16.1728
G01 X15.1440 Y16.1993
G01 X15.1659 Y16.2266
G01 X15.1868 Y16.2548
G01 X15.2066 Y16.2837
G01 X15.2253 Y16.3133
G01 X15.2430 Y16.3436
G01 X15.2594 Y16.3745
G01 X15.2748 Y16.4060
G01 X15.2889 Y16.4380
G01 X15.3019 Y16.4706
G01 X15.3136 Y16.5036
G01 X15.3241 Y16.5370
G01 X15.3205 Y16.5427
G01 X15.3165 Y16.5481
G01 X15.3122 Y16.5533
G01 X15.3075 Y16.5581
G01 X15.3024 Y16.5625
G01 X15.2971 Y16.5666
G01 X15.2915 Y16.5704
G01 X15.2856 Y16.5737
G01 X15.2795 Y16.5766
G01 X15.2733 Y16.5790
G01 X15.2668 Y16.5811
G01 X15.2603 Y16.5826
G01 X15.2536 Y16.5837
G01 X15.2469 Y16.5844
G01 X15.2402 Y16.5845
G01 X15.2335 Y16.5842
G01 X15.2268 Y16.5834
G01 X15.2202 Y16.5822
G01 X15.2137 Y16.5805
G01 X15.2073 Y16.5783
G01 X15.2011 Y16.5757
G01 X15.1950 Y16.5727
G01 X15.1893 Y16.5692
G01 X15.1837 Y16.5654
G01 X15.1785 Y16.5612
G01 X15.1735 Y16.5566
G01 X15.1689 Y16.5517
G01 X15.1647 Y16.5465
G01 X14.9913 Y16.4208
G01 X14.8235 Y16.2877
G01 X14.6618 Y16.1473
G01 X14.5064 Y16.0000
G01 X14.3576 Y15.8460
G01 X14.2156 Y15.6856
G01 X14.0809 Y15.5192
G01 X13.9535 Y15.3470
G01 X13.6679 Y14.9805
G01 X13.4110 Y14.5934
G01 X13.1844 Y14.1879
G01 X12.9893 Y13.7662
G01 X12.8269 Y13.3309
G01 X12.6981 Y12.8845
G01 X12.6037 Y12.4297
G01 X12.5442 Y11.9689
G01 X12.5200 Y11.5049
G01 X12.5312 Y11.0405
G01 X12.5777 Y10.5782
G01 X12.6593 Y10.1208
G01 X12.8021 Y9.4675
G01 X12.9796 Y8.8228
G01 X13.1913 Y8.1885
G01 X13.4365 Y7.5663
G01 X13.7145 Y6.9581
G01 X14.0246 Y6.3657
G01 X14.3659 Y5.7906
G01 X14.7374 Y5.2345
G01 X14.7534 Y5.2187
G01 X14.7681 Y5.2017
G01 X14.7815 Y5.1837
G01 X14.7934 Y5.1646
G01 X14.8039 Y5.1447
G01 X14.8128 Y5.1241
G01 X14.8201 Y5.1029
G01 X14.8258 Y5.0811
G01 X14.8256 Y5.0788
G01 X14.8252 Y5.0766
G01 X14.8247 Y5.0743
G01 X14.8240 Y5.0721
G01 X14.8232 Y5.0700
G01 X14.8223 Y5.0679
G01 X14.8212 Y5.0659
G01 X14.8200 Y5.0639
G01 X14.8186 Y5.0621
G01 X14.8172 Y5.0603
G01 X14.8156 Y5.0587
G01 X14.8139 Y5.0571
G01 X14.8121 Y5.0557
G01 X14.8102 Y5.0544
G01 X14.8083 Y5.0532
G01 X14.8062 Y5.0522
G01 X14.8041 Y5.0513
G01 X14.8019 Y5.0506
G01 X14.7997 Y5.0500
G01 X14.7975 Y5.0495
G01 X14.7952 Y5.0492
G01 X14.7929 Y5.0491
G01 X14.7906
G01 X14.7883 Y5.0492
G01 X14.3814 Y5.1035
G01 X13.9759 Y5.1674
G01 X13.5721 Y5.2410
G01 X13.1701 Y5.3241
G01 X12.7702 Y5.4168
G01 X12.3726 Y5.5189
G01 X11.9775 Y5.6305
G01 X11.5853 Y5.7515
G01 X11.1374 Y5.9012
G01 X10.6978 Y6.0738
G01 X10.2677 Y6.2688
G01 X9.8481 Y6.4856
G01 X9.4402 Y6.7236
G01 X9.0451 Y6.9822
G01 X8.6638 Y7.2608
G01 X8.2973 Y7.5587
G01 X7.9465 Y7.8749
G01 X7.6125 Y8.2088
G01 X7.2961 Y8.5593
G01 X6.9980 Y8.9256
G01 X6.8111 Y9.1839
G01 X6.6385 Y9.4519
G01 X6.4809 Y9.7290
G01 X6.3387 Y10.0143
G01 X6.2122 Y10.3069
G01 X6.1020 Y10.6061
G01 X6.0083 Y10.9108
G01 X5.9313 Y11.2201
G01 X5.8714 Y11.5332
G01 X5.8288 Y11.8492
G01 X5.8034 Y12.1669
G01 X5.7955 Y12.4856
G01 X5.7710 Y12.9207
G01 X5.7618 Y13.3564
G01 X5.7677 Y13.7921
G01 X5.7888 Y14.2273
G01 X5.8251 Y14.6616
G01 X5.8765 Y15.0943
G01 X5.9429 Y15.5250
G01 X6.0244 Y15.9531
G01 X6.2033 Y16.5098
G01 X6.4126 Y17.0557
G01 X6.6516 Y17.5894
G01 X6.9196 Y18.1091
G01 X7.2158 Y18.6132
G01 X7.5394 Y19.1003
G01 X7.8892 Y19.5688
G01 X8.2643 Y20.0173
G01 X8.2686 Y20.0220
G01 X8.2725 Y20.0269
G01 X8.2760 Y20.0322
G01 X8.2791 Y20.0376
G01 X8.2819 Y20.0433
G01 X8.2841 Y20.0492
G01 X8.2860 Y20.0552
G01 X8.2874 Y20.0614
G01 X8.2883 Y20.0676
G01 X8.2887 Y20.0739
G01 Y20.0802
G01 X8.2882 Y20.0865
G01 X8.2873 Y20.0927
G01 X8.2858 Y20.0989
G01 X8.2840 Y20.1049
G01 X8.2817 Y20.1108
G01 X8.2789 Y20.1164
G01 X8.2758 Y20.1219
G01 X8.2722 Y20.1271
G01 X8.2683 Y20.1320
G01 X8.2640 Y20.1366
G01 X8.2593 Y20.1409
G01 X8.2544 Y20.1449
G01 X8.2492 Y20.1484
G01 X8.2437 Y20.1516
G01 X8.2381 Y20.1543
G01 X8.2322 Y20.1566
G01 X8.2262 Y20.1585
G01 X8.2200 Y20.1599
G01 X8.2138 Y20.1608
G01 X8.2075 Y20.1613
G01 X8.2012
G01 X7.7619 Y19.8625
G01 X7.3397 Y19.5400
G01 X6.9357 Y19.1948
G01 X6.5512 Y18.8281
G01 X6.4865 Y18.7584
G01 X6.4177 Y18.6927
G01 X6.3450 Y18.6313
G01 X6.2688 Y18.5743
G01 X6.1892 Y18.5221
G01 X6.1067 Y18.4747
G01 X6.0215 Y18.4324
G01 X5.9338 Y18.3954
G01 X5.9227 Y18.3996
G01 X5.9119 Y18.4046
G01 X5.9014 Y18.4104
G01 X5.8914 Y18.4169
G01 X5.8819 Y18.4242
G01 X5.8730 Y18.4321
G01 X5.8646 Y18.4406
G01 X5.8569 Y18.4497
G01 X5.8499 Y18.4593
G01 X5.8435 Y18.4694
G01 X5.8379 Y18.4800
G01 X5.8331 Y18.4909
G01 X5.8291 Y18.5021
G01 X5.8259 Y18.5136
G01 X5.8235 Y18.5253
G01 X5.8220 Y18.5372
G01 X5.8214 Y18.5491
G01 X5.8216 Y18.5610
G01 X5.8226 Y18.5729
G01 X5.8245 Y18.5847
G01 X5.8273 Y18.5963
G01 X5.8309 Y18.6077
G01 X5.8353 Y18.6188
G01 X5.8405 Y18.6295
G01 X5.8464 Y18.6399
G01 X5.8531 Y18.6498
G01 X5.8604 Y18.6592
G01 X5.8685 Y18.6680
G01 X6.0093 Y19.0166
G01 X6.1675 Y19.3577
G01 X6.3427 Y19.6904
G01 X6.5344 Y20.0139
G01 X6.7421 Y20.3273
G01 X6.9654 Y20.6298
G01 X7.2036 Y20.9207
G01 X7.4562 Y21.1993
G01 X7.7224 Y21.4648
G01 X8.0017 Y21.7165
G01 X8.2933 Y21.9539
G01 X8.5965 Y22.1763
G01 X9.0772 Y22.5186
G01 X9.5717 Y22.8407
G01 X10.0790 Y23.1422
G01 X10.5984 Y23.4224
G01 X11.1289 Y23.6808
G01 X11.6697 Y23.9171
G01 X12.2198 Y24.1309
G01 X12.7782 Y24.3217
G01 X13.3441 Y24.4892
G01 X13.9164 Y24.6332
G01 X14.4942 Y24.7534
G01 X15.0764 Y24.8496
G01 X15.6621 Y24.9217
G01 X16.2504 Y24.9694
G01 X16.8400 Y24.9928
G01 X17.4302 Y24.9918
G01 X18.1059 Y24.9841
G01 X18.7812 Y24.9563
G01 X19.4553 Y24.9083
G01 X20.1276 Y24.8402
G01 X20.7977 Y24.7521
G01 X21.4648 Y24.6441
G01 X22.1284 Y24.5162
G01 X22.7878 Y24.3686
G01 X23.4426 Y24.2014
G01 X24.0921 Y24.0147
G01 X24.7358 Y23.8087
G01 X25.3730 Y23.5837
G01 X26.6873 Y23.1130
G01 X27.9948 Y22.6237
G01 X29.2951 Y22.1158
G01 X30.5881 Y21.5894
G01 X31.1215 Y21.3748
G01 X31.6598 Y21.1727
G01 X32.2026 Y20.9832
G01 X32.7497 Y20.8063
G01 X33.3008 Y20.6423
G01 X33.8555 Y20.4911
G01 X34.4136 Y20.3529
G01 X34.9748 Y20.2277
G01 X35.1925 Y20.1900
G01 X35.4109 Y20.1567
G01 X35.6299 Y20.1278
G01 X35.8494 Y20.1033
G01 X35.8585 Y20.1079
G01 X35.8644 Y20.1168
G01 X35.8622 Y20.1272
G01 X35.5798 Y20.4371
G01 X35.3149 Y20.7622
G01 X35.0684 Y21.1014
G01 X34.8410 Y21.4537
G01 X34.6189 Y21.9620
G01 X34.4299 Y22.4836
G01 X34.2746 Y23.0162
G01 X34.1539 Y23.5576
G01 X34.0680 Y24.1057
G01 X34.0175 Y24.6582
G01 X34.0026 Y25.2127
G01 X34.0231 Y25.7671
G01 X34.0366 Y25.8623
G01 X34.0554 Y25.9566
G01 X34.0793 Y26.0496
G01 X34.1085 Y26.1412
G01 X34.1427 Y26.2311
G01 X34.1819 Y26.3188
G01 X34.2260 Y26.4043
G01 X34.2747 Y26.4871
G01 X34.3280 Y26.5671
G01 X34.3857 Y26.6440
G01 X34.4476 Y26.7175
G01 X34.5135 Y26.7875
G01 X34.5469 Y26.8095
G01 X34.5813 Y26.8299
G01 X34.6166 Y26.8486
G01 X34.6528 Y26.8656
G01 X34.6898 Y26.8808
G01 X34.7274 Y26.8943
G01 X34.7657 Y26.9059
G01 X34.8044 Y26.9157
G01 X34.8436 Y26.9236
G01 X34.8831 Y26.9296
G01 X34.9229 Y26.9337
G01 X34.9628 Y26.9358
G01 X35.0028 Y26.9361
G01 X35.0428 Y26.9345
G01 X35.0826 Y26.9309
G01 X35.1222 Y26.9254
G01 X35.1615 Y26.9180
G01 X35.2004 Y26.9088
G01 X35.2388 Y26.8977
G01 X35.2766 Y26.8848
G01 X35.3138 Y26.8700
G01 X35.3502 Y26.8535
G01 X35.3858 Y26.8353
G01 X35.4204 Y26.8154
G01 X35.6083 Y26.7042
G01 X35.7884 Y26.5808
G01 X35.9598 Y26.4457
G01 X36.1218 Y26.2994
G01 X36.2738 Y26.1426
G01 X36.4149 Y25.9761
G01 X36.5446 Y25.8005
G01 X36.6623 Y25.6166
G01 X36.9508 Y25.1908
G01 X37.2206 Y24.7528
G01 X37.4711 Y24.3035
G01 X37.7019 Y23.8438
G01 X37.9125 Y23.3744
G01 X38.1025 Y22.8964
G01 X38.2717 Y22.4106
G01 X38.4195 Y21.9179
G01 X38.5459 Y21.4193
G01 X38.6505 Y20.9156
G01 X38.7331 Y20.4079
G01 X38.7936 Y19.8970
G01 X38.9184 Y18.5386
G01 X39.0105 Y17.1775
G01 X39.0700 Y15.8147
G01 X39.0967 Y14.4508
G01 X39.0671 Y14.2185
G01 X39.0218 Y13.9887
G01 X38.9610 Y13.7626
G01 X38.8850 Y13.5411
G01 X38.7942 Y13.3253
G01 X38.6888 Y13.1161
G01 X38.5696 Y12.9146
G01 X38.4369 Y12.7217
G01 X38.0297 Y12.1872
G01 X37.6032 Y11.6679
G01 X37.1580 Y11.1646
G01 X36.6946 Y10.6780
G01 X36.2137 Y10.2087
G01 X35.7160 Y9.7573
G01 X35.2020 Y9.3245
G01 X34.6725 Y8.9108
G01 X34.0231 Y8.4326
G01 X33.3640 Y7.9678
G01 X32.6955 Y7.5166
G01 X32.0179 Y7.0792
G01 X31.3314 Y6.6559
G01 X30.6364 Y6.2467
G01 X29.9332 Y5.8519
G01 X29.2220 Y5.4716
G01 X28.5129 Y5.1395
G01 X27.7917 Y4.8346
G01 X27.0595 Y4.5573
G01 X26.3172 Y4.3081
G01 X25.5660 Y4.0873
G01 X24.8069 Y3.8952
G01 X24.0411 Y3.7321
G01 X23.2697 Y3.5982
G01 X22.5275 Y3.5626
G01 X21.7845 Y3.5635
G01 X21.0424 Y3.6009
G01 X20.3031 Y3.6746
G01 X19.7724 Y3.7906
G01 X19.2495 Y3.9373
G01 X18.7359 Y4.1142
G01 X18.2334 Y4.3205
G01 X17.7438 Y4.5557
G01 X17.2687 Y4.8190
G01 X16.8097 Y5.1094
G01 X16.3684 Y5.4260
G01 X16.1351 Y5.6270
G01 X15.9106 Y5.8376
G01 X15.6952 Y6.0575
G01 X15.4892 Y6.2863
G01 X15.2930 Y6.5236
G01 X15.1070 Y6.7689
G01 X14.9316 Y7.0219
G01 X14.7669 Y7.2820
G00 Z5.0000
;No. 2: Engraving 129
G00 X19.3567 Y2.6922 Z5.0000
G00 Z0.5000
G01 Z0.0000 F1000
G01 Z-0.1000
G01 X20.0583 Y2.6081 F7000
G01 X20.7630 Y2.5550
G01 X21.4692 Y2.5329
G01 X22.1758 Y2.5419
G01 X22.8278 Y2.5340
G01 X23.4797 Y2.5494
G01 X24.1305 Y2.5881
G01 X24.7796 Y2.6502
G01 X25.1705 Y2.7281
G01 X25.5590 Y2.8174
G01 X25.9447 Y2.9182
G01 X26.3272 Y3.0303
G01 X26.7063 Y3.1536
G01 X27.0815 Y3.2881
G01 X27.4526 Y3.4335
G01 X27.8193 Y3.5898
G01 X28.5555 Y3.9098
G01 X29.2838 Y4.2473
G01 X30.0038 Y4.6021
G01 X30.7152 Y4.9739
G01 X31.4174 Y5.3627
G01 X32.1102 Y5.7681
G01 X32.7931 Y6.1900
G01 X33.4657 Y6.6280
G01 X34.1277 Y7.0820
G01 X34.7786 Y7.5517
G01 X35.4182 Y8.0368
G01 X36.0459 Y8.5370
G01 X36.4854 Y8.9060
G01 X36.9153 Y9.2860
G01 X37.3356 Y9.6768
G01 X37.7458 Y10.0781
G01 X38.1457 Y10.4896
G01 X38.5350 Y10.9111
G01 X38.9136 Y11.3423
G01 X39.2811 Y11.7830
G01 X39.4578 Y12.0093
G01 X39.6172 Y12.2482
G01 X39.7585 Y12.4982
G01 X39.8808 Y12.7579
G01 X39.9836 Y13.0261
G01 X40.0662 Y13.3011
G01 X40.1281 Y13.5815
G01 X40.1691 Y13.8657
G01 X40.1750 Y14.6768
G01 X40.1674 Y15.4879
G01 X40.1462 Y16.2988
G01 X40.1114 Y17.1092
G01 X40.0071 Y19.0923
G01 X39.8906 Y21.0747
G01 X39.7619 Y23.0563
G01 X39.6210 Y25.0372
G01 X39.5275 Y27.0208
G01 X39.4501 Y29.0052
G01 X39.3886 Y30.9901
G01 X39.3431 Y32.9755
G01 X39.3531 Y32.9806
G01 X40.3548 Y32.7072
G01 X41.3560 Y32.4322
G01 X42.3568 Y32.1557
G01 X43.3571 Y31.8775
G01 X44.3450 Y31.6507
G01 X45.3381 Y31.4476
G01 X46.3357 Y31.2682
G01 X47.3373 Y31.1126
G01 X47.4425 Y31.1016
G01 X47.5472 Y31.0865
G01 X47.6512 Y31.0673
G01 X47.7544 Y31.0441
G01 X47.8566 Y31.0168
G01 X47.9577 Y30.9856
G01 X48.0574 Y30.9504
G01 X48.1558 Y30.9114
G01 X48.2524 Y30.8685
G01 X48.3474 Y30.8218
G01 X48.4404 Y30.7715
G01 X48.5314 Y30.7176
G01 X48.6381 Y30.6323
G01 X48.7393 Y30.5406
G01 X48.8349 Y30.4431
G01 X48.9244 Y30.3399
G01 X49.0075 Y30.2315
G01 X49.0840 Y30.1183
G01 X49.1534 Y30.0007
G01 X49.2157 Y29.8792
G01 X50.1636 Y28.3288
G01 X51.0942 Y26.7678
G01 X52.0073 Y25.1966
G01 X52.9028 Y23.6153
G01 X53.5962 Y22.2522
G01 X54.2987 Y20.8938
G01 X55.0104 Y19.5401
G01 X55.7310 Y18.1912
G01 X56.0337 Y17.6875
G01 X56.3550 Y17.1954
G01 X56.6943 Y16.7156
G01 X57.0512 Y16.2488
G01 X57.4252 Y15.7955
G01 X57.8159 Y15.3565
G01 X58.2226 Y14.9323
G01 X58.6448 Y14.5235
G01 X59.2143 Y13.9631
G01 X59.8024 Y13.4224
G01 X60.4085 Y12.9019
G01 X61.0319 Y12.4022
G01 X61.6719 Y11.9240
G01 X62.3277 Y11.4677
G01 X62.9987 Y11.0339
G01 X63.6839 Y10.6231
G01 X64.3827 Y10.2358
G01 X65.0942 Y9.8724
G01 X65.8176 Y9.5333
G01 X66.5521 Y9.2190
G01 X67.2968 Y8.9297
G01 X68.0509 Y8.6658
G01 X68.8135 Y8.4277
G01 X69.5838 Y8.2155
G01 X70.2536 Y8.0380
G01 X70.9279 Y7.8782
G01 X71.6061 Y7.7363
G01 X72.2879 Y7.6123
G01 X72.9727 Y7.5063
G01 X73.6600 Y7.4184
G01 X74.3495 Y7.3487
G01 X75.0405 Y7.2973
G01 X75.7358 Y7.2852
G01 X76.4310 Y7.2964
G01 X77.1256 Y7.3307
G01 X77.8186 Y7.3882
G01 X78.5093 Y7.4687
G01 X79.1969 Y7.5723
G01 X79.8807 Y7.6987
G01 X80.5599 Y7.8479
G01 X80.9846 Y7.9447
G01 X81.4056 Y8.0563
G01 X81.8225 Y8.1826
G01 X82.2347 Y8.3235
G01 X82.6417 Y8.4788
G01 X83.0429 Y8.6482
G01 X83.4380 Y8.8317
G01 X83.8264 Y9.0288
G01 X84.2554 Y9.3239
G01 X84.6657 Y9.6444
G01 X85.0557 Y9.9893
G01 X85.4241 Y10.3573
G01 X86.4231 Y11.3401
G01 X87.4018 Y12.3432
G01 X88.3598 Y13.3662
G01 X89.2966 Y14.4085
G01 X89.6275 Y14.8312
G01 X89.9310 Y15.2740
G01 X90.2058 Y15.7352
G01 X90.4507 Y16.2129
G01 X90.6649 Y16.7051
G01 X90.8474 Y17.2100
G01 X90.9974 Y17.7254
G01 X91.1145 Y18.2493
G01 X91.1860 Y18.5582
G01 X91.2454 Y18.8696
G01 X91.2927 Y19.1830
G01 X91.3277 Y19.4981
G01 X91.3504 Y19.8143
G01 X91.3608 Y20.1312
G01 X91.3589 Y20.4482
G01 X91.3446 Y20.7649
G01 X91.3440 Y20.9350
G01 X91.3342 Y21.1047
G01 X91.3151 Y21.2737
G01 X91.2870 Y21.4415
G01 X91.2497 Y21.6074
G01 X91.2035 Y21.7711
G01 X91.1485 Y21.9320
G01 X91.0848 Y22.0897
G01 X90.9050 Y22.5649
G01 X90.6997 Y23.0297
G01 X90.4697 Y23.4828
G01 X90.2157 Y23.9228
G01 X89.9382 Y24.3485
G01 X89.6382 Y24.7586
G01 X89.3166 Y25.1519
G01 X88.9742 Y25.5273
G01 X88.6120 Y25.8837
G01 X88.2312 Y26.2201
G01 X87.8328 Y26.5354
G01 X87.4179 Y26.8288
G01 X86.9173 Y27.2776
G01 X86.4168 Y27.7265
G01 X85.9165 Y28.1757
G01 X85.4165 Y28.6251
G01 X85.0518 Y28.9259
G01 X84.6746 Y29.2109
G01 X84.2855 Y29.4795
G01 X83.8853 Y29.7311
G01 X83.4747 Y29.9653
G01 X83.0544 Y30.1818
G01 X82.6252 Y30.3800
G01 X82.1879 Y30.5597
G01 X81.6995 Y30.7232
G01 X81.2045 Y30.8656
G01 X80.7039 Y30.9867
G01 X80.1985 Y31.0861
G01 X79.6893 Y31.1638
G01 X79.1773 Y31.2195
G01 X78.6633 Y31.2532
G01 X78.1484 Y31.2649
G01 X77.7326 Y31.2426
G01 X77.3177 Y31.2060
G01 X76.9043 Y31.1551
G01 X76.4930 Y31.0901
G01 X76.0841 Y31.0109
G01 X75.6782 Y30.9177
G01 X75.2758 Y30.8106
G01 X74.8772 Y30.6897
G01 X74.0599 Y30.4247
G01 X73.2474 Y30.1453
G01 X72.4399 Y29.8518
G01 X71.6377 Y29.5441
G01 X70.8410 Y29.2223
G01 X70.0501 Y28.8867
G01 X69.2652 Y28.5372
G01 X68.4866 Y28.1740
G01 X67.0894 Y27.5165
G01 X65.6927 Y26.8581
G01 X64.2964 Y26.1989
G01 X62.9005 Y25.5388
G01 X62.2527 Y25.2317
G01 X61.5977 Y24.9403
G01 X60.9359 Y24.6648
G01 X60.2676 Y24.4054
G01 X60.2290 Y24.3887
G01 X60.1898 Y24.3737
G01 X60.1500 Y24.3605
G01 X60.1096 Y24.3490
G01 X60.0688 Y24.3392
G01 X60.0276 Y24.3312
G01 X59.9861 Y24.3251
G01 X59.9443 Y24.3207
G01 X59.9024 Y24.3181
G01 X59.8605 Y24.3174
G01 X59.8185 Y24.3185
G01 X59.7766 Y24.3214
G01 X59.7349 Y24.3261
G01 X59.6934 Y24.3326
G01 X59.6523 Y24.3409
G01 X59.6116 Y24.3510
G01 X59.5713 Y24.3628
G01 X59.5316 Y24.3764
G01 X59.4925 Y24.3917
G01 X59.4541 Y24.4086
G01 X59.4164 Y24.4272
G01 X59.3797 Y24.4475
G01 X59.3438 Y24.4693
G01 X59.3089 Y24.4926
G01 X59.2247 Y24.5654
G01 X59.1448 Y24.6429
G01 X59.0694 Y24.7248
G01 X58.9989 Y24.8109
G01 X58.9333 Y24.9009
G01 X58.8731 Y24.9945
G01 X58.8182 Y25.0914
G01 X58.7690 Y25.1913
G01 X58.4009 Y25.8576
G01 X58.0537 Y26.5351
G01 X57.7278 Y27.2230
G01 X57.4236 Y27.9208
G01 X57.1412 Y28.6278
G01 X56.8810 Y29.3432
G01 X56.6433 Y30.0664
G01 X56.4282 Y30.7966
G01 X56.3736 Y31.0044
G01 X56.3299 Y31.2148
G01 X56.2972 Y31.4271
G01 X56.2756 Y31.6409
G01 X56.2813 Y31.6529
G01 X56.2879 Y31.6645
G01 X56.2952 Y31.6756
G01 X56.3034 Y31.6861
G01 X56.3123 Y31.6960
G01 X56.3219 Y31.7053
G01 X56.3321 Y31.7138
G01 X56.3429 Y31.7215
G01 X56.3543 Y31.7284
G01 X56.3661 Y31.7345
G01 X56.3784 Y31.7398
G01 X56.3910 Y31.7441
G01 X56.4038 Y31.7475
G01 X56.4169 Y31.7499
G01 X56.4301 Y31.7514
G01 X56.4434 Y31.7519
G01 X57.0502 Y31.9666
G01 X57.6574 Y32.1803
G01 X58.2649 Y32.3930
G01 X58.8728 Y32.6047
G01 X59.5354 Y32.8376
G01 X60.1922 Y33.0864
G01 X60.8427 Y33.3511
G01 X61.4867 Y33.6314
G01 X62.1237 Y33.9273
G01 X62.7533 Y34.2384
G01 X63.3752 Y34.5648
G01 X63.9890 Y34.9061
G01 X64.5944 Y35.2622
G01 X65.1910 Y35.6328
G01 X65.7784 Y36.0178
G01 X66.3564 Y36.4168
G01 X66.5880 Y36.5777
G01 X66.8136 Y36.7468
G01 X67.0329 Y36.9241
G01 X67.2456 Y37.1092
G01 X67.4515 Y37.3019
G01 X67.6502 Y37.5020
G01 X67.8415 Y37.7091
G01 X68.0251 Y37.9231
G01 X68.0418 Y37.9489
G01 X68.0569 Y37.9757
G01 X68.0703 Y38.0033
G01 X68.0820 Y38.0317
G01 X68.0919 Y38.0608
G01 X68.1001 Y38.0904
G01 X68.1064 Y38.1205
G01 X68.1109 Y38.1509
G01 X68.1136 Y38.1815
G01 X68.1143 Y38.2122
G01 X68.1132 Y38.2429
G01 X68.1102 Y38.2735
G01 X68.1054 Y38.3038
G01 X68.0987 Y38.3338
G01 X68.0902 Y38.3633
G01 X68.0799 Y38.3923
G01 X68.0679 Y38.4206
G01 X68.0542 Y38.4481
G01 X68.0388 Y38.4747
G01 X68.0219 Y38.5003
G01 X67.6105 Y39.2740
G01 X67.1894 Y40.0425
G01 X66.7587 Y40.8057
G01 X66.3184 Y41.5633
G01 X66.2717 Y41.6393
G01 X66.2293 Y41.7178
G01 X66.1912 Y41.7984
G01 X66.1575 Y41.8810
G01 X66.1285 Y41.9653
G01 X66.1040 Y42.0510
G01 X66.0843 Y42.1380
G01 X66.0694 Y42.2259
G01 X66.0593 Y42.3145
G01 X66.0540 Y42.4036
G01 X66.0536 Y42.4927
G01 X66.0581 Y42.5818
G01 X66.0644 Y42.6108
G01 X66.0722 Y42.6394
G01 X66.0816 Y42.6676
G01 X66.0924 Y42.6952
G01 X66.1048 Y42.7222
G01 X66.1185 Y42.7485
G01 X66.1336 Y42.7740
G01 X66.1501 Y42.7987
G01 X66.1679 Y42.8224
G01 X66.1870 Y42.8452
G01 X66.2072 Y42.8669
G01 X66.2286 Y42.8874
G01 X66.2510 Y42.9069
G01 X66.2745 Y42.9250
G01 X66.2988 Y42.9419
G01 X66.3241 Y42.9575
G01 X66.6921 Y43.2078
G01 X67.0573 Y43.4621
G01 X67.4198 Y43.7203
G01 X67.7794 Y43.9824
G01 X68.2516 Y44.3791
G01 X68.7050 Y44.7970
G01 X69.1386 Y45.2354
G01 X69.5517 Y45.6934
G01 X69.9432 Y46.1698
G01 X70.3123 Y46.6637
G01 X70.6584 Y47.1742
G01 X70.9806 Y47.7000
G01 X71.1816 Y48.0675
G01 X71.3677 Y48.4428
G01 X71.5385 Y48.8253
G01 X71.6937 Y49.2144
G01 X71.8330 Y49.6094
G01 X71.9563 Y50.0097
G01 X72.0633 Y50.4147
G01 X72.1539 Y50.8237
G01 X72.1741 Y50.9463
G01 X72.1890 Y51.0696
G01 X72.1984 Y51.1935
G01 X72.2025 Y51.3177
G01 X72.2012 Y51.4419
G01 X72.1945 Y51.5659
G01 X72.1824 Y51.6896
G01 X72.1649 Y51.8126
G01 X72.1421 Y51.9347
G01 X72.1141 Y52.0557
G01 X72.0807 Y52.1754
G01 X72.0423 Y52.2935
G01 X71.9812 Y52.3910
G01 X71.9138 Y52.4841
G01 X71.8404 Y52.5727
G01 X71.7613 Y52.6561
G01 X71.6768 Y52.7342
G01 X71.5873 Y52.8064
G01 X71.4933 Y52.8726
G01 X71.3950 Y52.9324
G01 X71.2930 Y52.9855
G01 X71.1877 Y53.0318
G01 X71.0796 Y53.0709
G01 X70.9691 Y53.1028
G01 X70.8325 Y53.1413
G01 X70.6939 Y53.1720
G01 X70.5538 Y53.1949
G01 X70.4126 Y53.2099
G01 X70.2708 Y53.2169
G01 X70.1289 Y53.2159
G01 X69.9872 Y53.2069
G01 X69.8463 Y53.1900
G01 X69.7065 Y53.1652
G01 X69.5683 Y53.1325
G01 X69.4323 Y53.0921
G01 X69.2986 Y53.0442
G01 X68.8853 Y52.8971
G01 X68.4697 Y52.7566
G01 X68.0520 Y52.6226
G01 X67.6322 Y52.4953
G01 X67.5624 Y52.4834
G01 X67.4921 Y52.4747
G01 X67.4216 Y52.4691
G01 X67.3508 Y52.4667
G01 X67.2896 Y52.7146
G01 X67.2400 Y52.9650
G01 X67.2021 Y53.2175
G01 X67.1760 Y53.4715
G01 X67.1618 Y53.7264
G01 X67.1595 Y53.9817
G01 X67.1690 Y54.2369
G01 X67.1904 Y54.4913
G01 X67.3531 Y54.7702
G01 X67.5321 Y55.0390
G01 X67.7268 Y55.2966
G01 X67.9365 Y55.5421
G01 X68.0268 Y55.6633
G01 X68.1102 Y55.7893
G01 X68.1865 Y55.9197
G01 X68.2555 Y56.0541
G01 X68.3169 Y56.1921
G01 X68.3706 Y56.3333
G01 X68.4164 Y56.4773
G01 X68.4542 Y56.6236
G01 X68.4838 Y56.7717
G01 X68.5052 Y56.9213
G01 X68.5182 Y57.0718
G01 X68.5229 Y57.2228
G01 X68.5640 Y57.8082
G01 X68.5991 Y58.3941
G01 X68.6280 Y58.9803
G01 X68.6508 Y59.5667
G01 X70.1629 Y60.4722
G01 X71.6624 Y61.3984
G01 X73.1490 Y62.3453
G01 X74.6223 Y63.3126
G01 X75.0386 Y63.5962
G01 X75.4460 Y63.8923
G01 X75.8443 Y64.2007
G01 X76.2330 Y64.5210
G01 X76.6118 Y64.8530
G01 X76.9804 Y65.1963
G01 X77.3383 Y65.5507
G01 X77.6854 Y65.9158
G01 X77.8593 Y66.1077
G01 X78.0245 Y66.3072
G01 X78.1808 Y66.5139
G01 X78.3276 Y66.7273
G01 X78.4649 Y66.9470
G01 X78.5922 Y67.1726
G01 X78.7094 Y67.4036
G01 X78.8162 Y67.6396
G01 X78.8527 Y67.7391
G01 X78.8820 Y67.8409
G01 X78.9040 Y67.9445
G01 X78.9186 Y68.0494
G01 X78.9257 Y68.1551
G01 X78.9253 Y68.2610
G01 X78.9173 Y68.3667
G01 X78.9019 Y68.4715
G01 X78.8791 Y68.5749
G01 X78.8490 Y68.6765
G01 X78.8118 Y68.7756
G01 X78.7676 Y68.8719
G01 X78.6158 Y69.2344
G01 X78.4519 Y69.5915
G01 X78.2759 Y69.9428
G01 X78.0882 Y70.2881
G01 X77.8888 Y70.6267
G01 X77.6781 Y70.9584
G01 X77.4564 Y71.2828
G01 X77.2237 Y71.5995
G01 X76.6969 Y72.3044
G01 X76.1562 Y72.9988
G01 X75.6019 Y73.6823
G01 X75.0342 Y74.3548
G01 X74.4534 Y75.0159
G01 X73.8596 Y75.6654
G01 X73.2531 Y76.3031
G01 X72.6341 Y76.9287
G01 X71.6534 Y77.9128
G01 X70.6573 Y78.8814
G01 X69.6460 Y79.8342
G01 X68.6199 Y80.7709
G01 X68.5266 Y80.8358
G01 X68.4289 Y80.8937
G01 X68.3273 Y80.9444
G01 X68.2222 Y80.9875
G01 X68.1143 Y81.0229
G01 X68.0041 Y81.0504
G01 X67.8922 Y81.0698
G01 X67.7792 Y81.0810
G01 X67.6657 Y81.0840
G01 X67.5522 Y81.0787
G01 X67.4395 Y81.0652
G01 X67.3280 Y81.0436
G01 X67.3161 Y81.0172
G01 X67.3058 Y80.9901
G01 X67.2971 Y80.9625
G01 X67.2901 Y80.9343
G01 X67.2848 Y80.9059
G01 X67.2811 Y80.8771
G01 X67.2792 Y80.8482
G01 X67.2790 Y80.8193
G01 X67.2806 Y80.7903
G01 X67.2838 Y80.7615
G01 X67.2888 Y80.7330
G01 X67.2954 Y80.7048
G01 X67.3037 Y80.6770
G01 X67.3136 Y80.6498
G01 X67.3252 Y80.6233
G01 X67.3383 Y80.5974
G01 X67.5125 Y80.1301
G01 X67.6921 Y79.6649
G01 X67.8771 Y79.2017
G01 X68.0674 Y78.7407
G01 X68.2546 Y78.1429
G01 X68.4191 Y77.5385
G01 X68.5606 Y76.9282
G01 X68.6789 Y76.3131
G01 X68.7739 Y75.6939
G01 X68.8453 Y75.0716
G01 X68.8932 Y74.4470
G01 X68.9174 Y73.8211
G01 X68.9480 Y73.0626
G01 X68.9705 Y72.3038
G01 X68.9847 Y71.5448
G01 X68.9907 Y70.7857
G01 X70.0149 Y69.7924
G01 X71.0392 Y68.7991
G01 X70.4281 Y68.5098
G01 X69.8316 Y68.1914
G01 X69.2512 Y67.8447
G01 X68.6881 Y67.4704
G01 X68.4528 Y67.2901
G01 X68.2045 Y67.1283
G01 X67.9445 Y66.9859
G01 X67.6744 Y66.8639
G01 X67.6666 Y66.8615
G01 X67.6587 Y66.8597
G01 X67.6506 Y66.8585
G01 X67.6425 Y66.8579
G01 X67.6344 Y66.8578
G01 X67.6263 Y66.8584
G01 X67.6182 Y66.8595
G01 X67.6103 Y66.8613
G01 X67.6025 Y66.8636
G01 X67.5949 Y66.8665
G01 X67.5876 Y66.8699
G01 X67.5805 Y66.8739
G01 X67.5737 Y66.8783
G01 X67.5672 Y66.8833
G01 X67.5612 Y66.8887
G01 X67.5555 Y66.8945
G01 X67.5503 Y66.9007
G01 X67.5456 Y66.9073
G01 X67.5413 Y66.9143
G01 X67.5376 Y66.9215
G01 X67.5344 Y66.9290
G01 X67.5318 Y66.9367
G01 X67.5297 Y66.9445
G01 X67.5282 Y66.9525
G01 X67.5273 Y66.9606
G01 X67.5270 Y66.9687
G01 X67.5273 Y66.9768
G01 X67.5282 Y66.9849
G01 X67.5297 Y66.9929
G01 X67.5318 Y67.0007
G01 X67.5344 Y67.0084
G01 X67.5376 Y67.0159
G01 X67.6584 Y67.6298
G01 X67.7653 Y68.2462
G01 X67.8583 Y68.8648
G01 X67.9374 Y69.4854
G01 X67.9898 Y69.9979
G01 X68.0312 Y70.5114
G01 X68.0617 Y71.0256
G01 X68.0812 Y71.5404
G01 X68.0897 Y72.0554
G01 X68.0872 Y72.5705
G01 X68.0737 Y73.0855
G01 X68.0492 Y73.6001
G01 X67.9252 Y74.4316
G01 X67.7711 Y75.2581
G01 X67.5871 Y76.0785
G01 X67.3735 Y76.8917
G01 X67.0935 Y77.9525
G01 X66.8116 Y79.0128
G01 X66.5279 Y80.0726
G01 X66.2423 Y81.1319
G01 X66.0651 Y81.8601
G01 X65.9045 Y82.5922
G01 X65.7608 Y83.3278
G01 X65.6340 Y84.0665
G01 X65.6261 Y84.0974
G01 X65.6200 Y84.1286
G01 X65.6159 Y84.1602
G01 X65.6137 Y84.1920
G01 X65.6134 Y84.2238
G01 X65.6150 Y84.2556
G01 X65.6186 Y84.2873
G01 X65.6241 Y84.3187
G01 X65.6315 Y84.3496
G01 X65.6407 Y84.3801
G01 X65.6518 Y84.4100
G01 X65.6646 Y84.4391
G01 X65.7470 Y84.5253
G01 X65.8355 Y84.6052
G01 X65.9297 Y84.6784
G01 X66.0289 Y84.7445
G01 X66.1327 Y84.8031
G01 X66.2406 Y84.8540
G01 X66.3519 Y84.8968
G01 X66.4660 Y84.9314
G01 X66.9174 Y85.0924
G01 X67.3610 Y85.2738
G01 X67.7959 Y85.4750
G01 X68.2213 Y85.6957
G01 X68.6363 Y85.9355
G01 X69.0400 Y86.1938
G01 X69.4315 Y86.4701
G01 X69.8102 Y86.7639
G01 X70.1751 Y87.0745
G01 X70.5256 Y87.4014
G01 X70.8610 Y87.7438
G01 X71.1804 Y88.1010
G01 X71.6328 Y88.6359
G01 X72.0875 Y89.1689
G01 X72.5445 Y89.6998
G01 X73.0038 Y90.2288
G01 X74.2613 Y91.5415
G01 X75.5278 Y92.8454
G01 X76.8035 Y94.1403
G01 X78.0882 Y95.4264
G01 X78.5021 Y95.8403
G01 X78.9056 Y96.2644
G01 X79.2985 Y96.6982
G01 X79.6807 Y97.1416
G01 X80.0519 Y97.5942
G01 X80.4118 Y98.0559
G01 X80.7602 Y98.5262
G01 X81.0970 Y99.0050
G01 X81.5570 Y99.7567
G01 X81.9859 Y100.5265
G01 X82.3829 Y101.3133
G01 X82.7475 Y102.1156
G01 X83.0789 Y102.9321
G01 X83.3766 Y103.7615
G01 X83.6402 Y104.6024
G01 X83.8692 Y105.4534
G01 X83.9926 Y106.0520
G01 X84.0818 Y106.6567
G01 X84.1365 Y107.2654
G01 X84.1564 Y107.8763
G01 X84.1415 Y108.4873
G01 X84.0920 Y109.0965
G01 X84.0078 Y109.7019
G01 X83.8894 Y110.3015
G01 X83.8427 Y110.4157
G01 X83.7911 Y110.5278
G01 X83.7346 Y110.6375
G01 X83.6735 Y110.7447
G01 X83.6077 Y110.8492
G01 X83.5375 Y110.9507
G01 X83.4630 Y111.0490
G01 X83.3842 Y111.1440
G01 X83.3014 Y111.2355
G01 X83.2147 Y111.3234
G01 X83.1243 Y111.4073
G01 X83.0303 Y111.4873
G01 X82.9606 Y111.5644
G01 X82.8871 Y111.6380
G01 X82.8102 Y111.7079
G01 X82.7300 Y111.7740
G01 X82.6466 Y111.8361
G01 X82.5604 Y111.8941
G01 X82.4714 Y111.9478
G01 X82.3799 Y111.9972
G01 X82.2861 Y112.0420
G01 X82.1902 Y112.0822
G01 X82.0925 Y112.1177
G01 X81.9932 Y112.1484
G01 X81.9039 Y112.1578
G01 X81.8150 Y112.1703
G01 X81.7265 Y112.1861
G01 X81.6387 Y112.2050
G01 X81.5517 Y112.2271
G01 X81.4655 Y112.2523
G01 X81.3802 Y112.2807
G01 X81.2961 Y112.3120
G01 X81.2635 Y112.3271
G01 X81.2318 Y112.3441
G01 X81.2013 Y112.3630
G01 X81.1719 Y112.3838
G01 X81.1439 Y112.4064
G01 X81.1174 Y112.4306
G01 X81.0924 Y112.4564
G01 X81.0690 Y112.4836
G01 X81.0473 Y112.5123
G01 X81.0274 Y112.5423
G01 X81.0094 Y112.5734
G01 X80.9933 Y112.6055
G01 X80.9793 Y112.6386
G01 X80.9673 Y112.6725
G01 X80.9574 Y112.7070
G01 X80.9496 Y112.7421
G01 X80.9440 Y112.7776
G01 X80.9406 Y112.8134
G01 X80.9395 Y112.8493
G01 X80.9405 Y112.8852
G01 X80.9248 Y113.1510
G01 X80.9257 Y113.4172
G01 X80.9433 Y113.6829
G01 X80.9774 Y113.9469
G01 X81.0925 Y115.1864
G01 X81.1898 Y116.4274
G01 X81.2692 Y117.6698
G01 X81.3306 Y118.9131
G01 X81.3741 Y120.1572
G01 X81.3997 Y121.4017
G01 X81.4073 Y122.6466
G01 X81.3970 Y123.8914
G01 X81.4077 Y125.0077
G01 X81.3901 Y126.1239
G01 X81.3442 Y127.2392
G01 X81.2701 Y128.3531
G01 X81.1714 Y129.3549
G01 X81.0457 Y130.3536
G01 X80.8931 Y131.3486
G01 X80.7136 Y132.3391
G01 X80.5073 Y133.3244
G01 X80.2745 Y134.3037
G01 X80.0153 Y135.2764
G01 X79.7299 Y136.2417
G01 X79.6292 Y136.5667
G01 X79.5172 Y136.8880
G01 X79.3939 Y137.2052
G01 X79.2596 Y137.5178
G01 X79.1144 Y137.8255
G01 X78.9584 Y138.1279
G01 X78.7919 Y138.4247
G01 X78.6151 Y138.7154
G01 X78.5520 Y138.8097
G01 X78.4850 Y138.9012
G01 X78.4142 Y138.9898
G01 X78.3397 Y139.0754
G01 X78.2617 Y139.1577
G01 X78.1803 Y139.2367
G01 X78.0956 Y139.3122
G01 X78.0078 Y139.3840
G01 X77.9171 Y139.4521
G01 X77.8235 Y139.5163
G01 X77.7274 Y139.5765
G01 X77.6287 Y139.6325
G01 X77.6027 Y139.6336
G01 X77.5767 Y139.6329
G01 X77.5508 Y139.6306
G01 X77.5251 Y139.6267
G01 X77.4997 Y139.6210
G01 X77.4747 Y139.6138
G01 X77.4503 Y139.6049
G01 X77.4264 Y139.5945
G01 X77.4033 Y139.5826
G01 X77.3810 Y139.5692
G01 X77.3596 Y139.5544
G01 X77.3392 Y139.5383
G01 X77.3199 Y139.5208
G01 X77.3017 Y139.5022
G01 X77.2848 Y139.4824
G01 X77.2692 Y139.4616
G01 X77.2550 Y139.4398
G01 X77.2422 Y139.4171
G01 X77.2309 Y139.3937
G01 X77.2212 Y139.3696
G01 X77.1875 Y139.3043
G01 X77.1569 Y139.2375
To clarify, the above gcode sections are just snippets, there’s a character limit that prevents me from posting it all.
That looks huge! What are the dimensions of your rig?
EDIT: Sorry, it’s in the title, isn’t it… :sweat_smile:
Is that 1x1M work area, or over all?
I’ll post the link for you
Ps. Nice build
Yea, that’s a touch big. Won’t be doing metal on that. At least not well.
What did you use to generate the gcode for this?
Not having a G3 on each line is a little odd.
Using R instead of I, J is a little odd too. Not sure if either of these are causing issues.
@barry99705
Yeah, this build is for wood and plotting. I have a box-way vertical machining center for that sort of stuff anyway.
@Strider_Matic
1 m by 1 m work area.
@jeffeb3
I used DarkAlchemist’s Solidworks CAM post processor available on this forum and thingiverse. It seems like there’s another SW post processor, but it crashed SW on me. The G1 code was obviously estlcam.
You can paste the code snippets here and see the gcode simulation looks correct:
https://nraynaud.github.io/webgcode/
One more plot test… shaky video warning… (G1s):
https://youtu.be/RQQsSypYSSU
I’m guessing it is valid gcode, but gcode isn’t really that standard. I am guessing something about the way those commands are defined is reaching code that has a bug in it, but isn’t well tested.
You can turn on arcs in estlcam and see of those work (they should). That would narrow it down.
If anyone is interested in a table like this, I made a cut list and print. After building it, I do not think items 11 and 12 are necessary. Also, I plan on on making item 7 one single piece that is notched to fit as a cross beam.
Started working on a control box before I noticed some one already had a nice looking one on the forum. I’ll probably quit work on this as long as the walls are beefy on the one I found, but if anyone is interested is have the Solidworks files… I printed one from thingiverse but it was way too flimsy for my tastes.
LCD opening not cut out yet
Transparent to see internal fan mount
Section View
