Ok, I am working on my first piece and I entered the starting GCodes from this site into ESTLCAM, I start it up and it sets X & Y using dual endstops. Then I set Z to the top of the wood scrap I am using using the clamps and metal piece. When I do this, start the router and click the button to have it start on the Rambo 1.4 I got from the shop here, it just dives in way more than the 2mm I set in ESTLCAM to start… In ESTLCAM the preview looks good, I do not see it plunging like that…
Here is an excerpt of the GCode, anyone have any thoughts about what silly thing I have done here?
I let it go the first time, it ripped the plastic off the bit and plunged down to the metal cuff so I may be a bit gun shy.
G90 ; Absolute positioning, just in case
G92 X0 Y0 Z0 ; Set Current position to 0, all axes
G00 Z5.0000 F500 ; Raise Z 5mm at 8.3mm/s to clear clamps and screws
G28 X Y Z ; Home in order, w/zprobe
G92 Z0.15 ; Account for probe thickness (set your thickness)
G00 Z5.0000 F500 ; Raise Z probe off off of surface
M00 ; pause for LCD button press
M03 S24000 ; PID, set spindle speed
G00 X0.0000 Y0.0000 Z0.0000 F2100
G00 Z2.0000 F480
;No. 1: Engraving 24
G00 X1.4423 Y0.6556 F2100
G00 Z0.5000 F480
G01 Z0.0000 F180 S24000
G01 Z-1.0000 F180
G01 Y170.2040 F480
G01 X100.3100 F480
G01 Y1.4491 F480
G01 X0.6488 F480
G01 Z-2.0000 F180
G01 X100.3100 F480
G01 Y170.2040 F480
G01 X1.4423 F480
G01 Y0.6556 F480
G00 Z2.0000 F480
