I build my MPCNC Primo with the BigtreeTech SKR Pro V1.2 dual Endstops and uses the RepRapFirmware with an ESP WiFi Web Interface.
The RRF Firmware is much better than Marlin for me because you can change mostly everything on the Machine without recompile and flash the firmware again and again…
I have installed a upper Z end stop and dual stops on X and Y, the stops also wired low level triggered. So the switch disconnects between the pin and gnd if triggered.
I do have build my MPCNC with 1200 x 800 x 150mm size, so you need to adopt the config.g the M208 S0 values and also the values in the homeall.g homex.g homey.g homez.g too.
Today BTT also release a update for their TFT Firmware which makes it usable for the first time with RRF and Printing --> Not the CNC Version but is is promising that we will see here some progress soon to.
