I used Ryans firmware and it worked a first. it didn’t have dual stepper enabled so I enabled it. I got this error.
#error “No E stepper plug left for Y2!”
any help is appreciated thanks
I don’t think you need that enabled if you’re wired in series?
edit: all i had to do was set marlin to 0 extruders.
Unless you’re also running dual-endstops, there’s no real advantage to running dual steppers. You don’t lose any appreciable power by running in series, and it is actually a simpler build (and simpler trouble-shoot when things inevitably go wrong).
i am running dual endstop
Sounds like you have it worked out. We do also have a lot of configurations made up in marlinbuilder releases.
