If you can swing it, but the flat parts with the mpcnc first. You’ll need the skate wheels, and new tube, but the electrical parts and bearings will work. Oh, and a new router.
I did this. Some of the bolts should be shorter but end up working out OK if you pay attention to the order. I used to have a list, but I can’t find it. Not too bad to list compare the two boms. I did it on a lunch break.
You’ll definitely have some parts left over, but you’ll also definitely need another lead screw and coupler.
I keep thinking about doing this too. If you don’t mind, I’d love it if you documented your process here. I think others have done it, but no one’s bothered to write up how/what all they had to do to make that happen.
Thanks for the replies!
I am looking at the build directions: https://www.v1engineering.com/lowrider-cnc/
The table section is a little sparse. Am I looking at all of this correctly, the wheels are sitting on the top of the table?
looking at how I might make the table top: https://jscalc.io/calc/Ea1pVUNBCQdV9cPF
by my math I would need to use two 5x5 sheets. Any suggestions on how to join the two together to make a level table?
The wheels do ride on the table top, but some have also added a track of sorts on top of that. Pay special attention to the total depth of the table, as the lower z tube rollers tuck under it slightly. Lots of really great ideas for tables in the build threads, and most of them are better than anything I’d tell you…
